Thanks bakerman
Added the code (possibly in the wrong place) and set the Enabled-property of the CB's and both TB's to False
If i select date and machine and press Transfer Button it messagebox says "Select a Part"...i press OK and it give a Runtime Error 2110.....
Could this be where i placed the code as you mentioned on top of CommandButton1_Click...i could not get it to place above the CommandButton1_Click which may cause the error
Thanks again
