1) Remove the Tags from XFLOW A+B+C and put next code on top of CommandButton1_Click.
2) In designmode set the Enabled-property of the CB's and both TB's to False.Code:For Each ctl In Frame1.Controls If TypeName(ctl) = "OptionButton" Then If ctl.Value = False Then x = x + 1 End If Next If x = 3 Then MsgBox "Select a machine before you write data": Exit Sub
