Thanks Bakerman
I added a couple of text box`s to the userform and changed in the code...the data transfers to the correct cells...your code change for the Optionbutton works well but my only change is how can the code be changed because if I select say Internal by mistake I cannot then select External unless I close the userform and re-open then select External... say if I select Internal but then change my mind could I then select External (and visa-versa) .. I want to be able to select 1 of the Optionbuttons but if I change my mind then I can select the other Optionbutton....the combobox`s still only work though with the selected Optionbutton
