Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: changing code from using Combobox to optionbuttons
    Mar 2013
    The code worked fine while using Combobox`s but I prefer to use Optionbuttons in a few changes.I searched but have not worked out how to change the code from combobox to optionbutton
    1. Userform Machine Stoppage - use optionbutton to select machine instead of Combobox2
    Internal and External optiobuttons used instead of Combobox3
    2. Userform Planned Stop - use optionbutton to select Machine instead of Combobox2
    3. Userform Production- use optionbutton to select Machine instead of Combobox2
    Paul
    Moderator
    Jul 2012
    For Machine_Stoppage.
        'check user input
        For Each ctl In Me.Controls
            If ctl.Tag <> vbNullString Then
                If ctl.Value = vbNullString Then MsgBox ctl.Tag: ctl.SetFocus: Exit Sub
        For I = 1 To 3
            If Me("OptionButton" & I) Then whatsheet = Me("OptionButton" & I).Caption
        'write data to worksheet
        With Sheets(whatsheet)
           .Unprotect Password:="abc"
           .Cells(.Cells(.Rows.Count, "B").End(xlUp).Row + 1, 2).Resize(, 17) = Array(ComboBox1.Value, , , , , , , , _
                ComboBox2.Value, ComboBox3.Value, ComboBox4.Value, , IIf(OptionButton4, TextBox1.Text, ""), _
                ComboBox5.Value, ComboBox6.Value, , IIf(OptionButton5, TextBox1.Text, ""))
            .Protect Password:="abc"
        'Clear all fields
            If TypeName(ctl) = "TextBox" Or TypeName(ctl) = "ComboBox" Then ctl.Value = vbNullString
            If TypeName(ctl) = "OptionButton" Then ctl.Value = False
    I guess you can figure it out now for the other UF
    Mar 2013
    Thank you bakerman
    I made a few changes which at least allowed me to open the userform.The date now appears in Combobox1...i deleted some code from the Post#1 sheet...I am still not there with the optionbuttons...i have done search on net
    What books do you recommend for learning VBA?
    Thanks for your help
    Paul
    Moderator
    Jul 2012
    Why did you change this part ??
        For I = 1 To 3
            If Me("OptionButton" & I) Then Sheets("XFLOW A,XFLOW B,XFLOW C") = Me("OptionButton" & I).Caption
        With Sheets("XFLOW A,XFLOW B,XFLOW C")
    The purpose of the variable 'whatsheet' is to store the OptionButtons caption so you can use it in the With sheets(whatsheet) to write to the correct sheet.
    Mar 2013
    I though whatsheet is if you were asking me what sheets...another point learnt
    I am not sure with the Private Sub category_select()....i did change the comboboxs around but they are not visible in the userform....
    I will keep trying
    Paul
    You'd better remove all merged cells.
    in the userform machine stoppage this will suffice in the initialize event:
        ComboBox1.List = [transpose(text(today()-3+row(1:5),"dd-mmm-yyyy"))]
        sn = Sheets("INFO").Cells(3, 3).CurrentRegion.Offset(2)
        For j = 2 To 6
          Me("combobox" & j).List = Application.Index(sn, 0, j - 1)
    NB posting a non protected sample workbook would help the helpers a lot !
    Mar 2013
    thank you
    password = abc
    The info is now available in the userform...when I select Internal I need the External Option unavailable and visa versa....for this to work would I need both the Internal and External optionbuttons in the same Frame?
    Thanks again
    Mar 2013
    If Internal optionbutton selected then External optionbutton and its comboboxs not available and if External optionbutton selected then Internal optionbutton and its comboboxs are not available
    Moderator
    Jul 2012
    This works for me.
    Mar 2013
    Thanks Bakerman
    I added a couple of text box`s to the userform and changed in the code...the data transfers to the correct cells...your code change for the Optionbutton works well but my only change is how can the code be changed because if I select say Internal by mistake I cannot then select External unless I close the userform and re-open then select External... say if I select Internal but then change my mind could I then select External (and visa-versa) .. I want to be able to select 1 of the Optionbuttons but if I change my mind then I can select the other Optionbutton....the combobox`s still only work though with the selected Optionbutton
  1. Replies: 8
    Last Post: 08-17-2013, 04:03 AM
  2. Changing Picture Using Data Validation
    By jeff in forum Excel Help
    Last Post: 08-03-2013, 09:39 AM
  3. adding entries into combobox with code
    Last Post: 07-23-2013, 01:01 PM
  4. Changing Slideshow viewing mode to kiosk using vba
    By Times in forum Powerpoint Help
    Last Post: 05-10-2013, 12:37 AM
  5. Changing Hyperlink To Another Sheet By Changing Value Of Cell
    Last Post: 04-30-2011, 11:55 PM
