Thread: data entry to correct cell range...code needs help
    Mar 2013
    I have userform "Production" transferring data to the correct cell range....need help getting the code to transfer "Planned Stop" and Machine Stoppage
    All dates for Userforms called "Production","Planned Stop" and Machine Stoppage go into Column B in the sheets..
    Planned Stop data transfers to Column G,H and I
    Machine Stoppage data transfers to Columns J,K,L,M,N,O,P,Q
    When data is entered by any of the 3 userforms into the sheets that there is only 1 entry per row....sample:if data is entered in row 15 for XFLOW A for production then the next entry into XFLOW A sheet goes into row 16....please see example sheet attached for sheet XFLOW A
    Example:When an entry is entered in say Production for row 15 can the empty cells for Planned Stop and Machine Stoppage in row 15 automatically color Red
    Paul
    Moderator
    Jul 2012
    For UF Production
        'check user input
        For Each ctl In Me.Controls
            If ctl.Tag <> vbNullString Then
                If ctl.Value = vbNullString Then MsgBox ctl.Tag: ctl.SetFocus: Exit Sub
        'write data to worksheet
        With Sheets(ComboBox2.Value)
           .Unprotect Password:="abc"
           .Cells(.Cells(.Rows.Count, "B").End(xlUp).Row + 1, 2).Resize(, 5) = Array(ComboBox1.Value, _
                ComboBox3.Value, TextBox1.Text, TextBox3.Text, TextBox4.Text)
           .Cells(.Cells(.Rows.Count, "B").End(xlUp).Row, 2).Offset(, 5).Resize(, 11).Interior.ColorIndex = 3
            .Protect Password:="abc"
        'Clear all fields
            If TypeName(ctl) = "TextBox" Or TypeName(ctl) = "ComboBox" Then ctl.Value = vbNullString
    For UF Planned_Stop
        'check user input
           .Cells(.Cells(.Rows.Count, "B").End(xlUp).Row + 1, 2).Resize(, 8) = Array(ComboBox1.Value, , , , , _
                ComboBox3.Value, TextBox1.Text, TextBox2.Text)
        'Clear all fields
    For UF MachineStoppage
        'check user input
           .Cells(.Cells(.Rows.Count, "B").End(xlUp).Row + 1, 2).Resize(, 16) = Array(ComboBox1.Value, , , , , , , , _
                ComboBox4.Value, ComboBox5.Value, ComboBox6.Value, IIf(ComboBox3.ListIndex = 0, TextBox2.Text, ""), _
                ComboBox7.Value, ComboBox8.Value, IIf(ComboBox3.ListIndex = 1, TextBox2.Text, ""), TextBox1.Text)
        'Clear all fields
    Mar 2013
    Very nice bakerman...it worked on the Userform which was attached in Post#1
    I have changed the Combobox2 on the 3 userforms which selects which machine and replaced with optionbuttons...also replaced combobox3 in the machinestoppage userform
    I am stuck on how to use the optionbuttons in the codes instead of the combobox`s so it transfers data to the correct sheets and cells.....currently all 3 userforms give errors.......
    Paul
  1. Replies: 4
    Last Post: 07-27-2013, 01:34 PM
  2. VBA code to delete cell ranges
    Last Post: 07-08-2013, 09:18 AM
  3. Replies: 2
    Last Post: 05-30-2013, 07:28 PM
  4. Removing unused Cell styles - need an efficient code
    By siddharthsindhwani in forum Excel Help
    Last Post: 04-15-2013, 07:12 AM
  5. Replies: 14
    Last Post: 01-26-2013, 04:58 AM
