Results 1 to 7 of 7
Thread: Covert SQL Code to VBA
    Member ayazgreat's Avatar
    Mar 2012
    Hi All
    I have downloaded attached workbook from a web side and the code used in this work is in SQL , which are difficult for me to understand I want to know that if attached workbook code can be converted to VBA.
    Thanks in advance
    Somthing is better than nothing
    Moderator
    Jul 2012
    This is only for copying the results, not for filling the CB's.
    If you want that changed to VBA also, just ask.
    Also change the range of dataset to "B12:K12"
    Private Sub cmdShowData_Click()
        Dim rngTarget As Range, i As Integer
        Sheets("View").Range("dataSet").CurrentRegion.Offset(1).ClearContents
        With Worksheets("data")
            Set rngTarget = .Range("A1:J" & .Cells(Rows.Count, 1).End(xlUp).Row)
            With rngTarget
                For i = 1 To 3
                    .AutoFilter i + 2, Choose(i, cmbProducts.Text, cmbRegion.Text, cmbCustomerType.Text)
                .Offset(1).SpecialCells(xlCellTypeVisible).Copy Sheets("View").Range("B13")
                .AutoFilter
    Mar 2012
    Thanks bakerman for your reply but you have converted only one macro of attached workbook there are more macros/code in attached workbook
    Private Sub cmdReset_Click()
        'clear the data
        cmbProducts.Clear
        cmbCustomerType.Clear
        cmbRegion.Clear
        Sheets("View").Visible = True
        Sheets("View").Select
        Range("dataSet").Select
        Range(Selection, Selection.End(xlDown)).ClearContents
        'populate data
        strSQL = "SELECT * FROM [data$] WHERE "
        If cmbProducts.Text <> "" Then
            strSQL = strSQL & " [Product]='" & cmbProducts.Text & "'"
        If cmbRegion.Text <> "" Then
                strSQL = strSQL & " AND [Region]='" & cmbRegion.Text & "'"
                strSQL = strSQL & " [Region]='" & cmbRegion.Text & "'"
        If cmbCustomerType.Text <> "" Then
            If cmbProducts.Text <> "" Or cmbRegion.Text <> "" Then
                strSQL = strSQL & " AND [Customer Type]='" & cmbCustomerType.Text & "'"
                strSQL = strSQL & " [Customer Type]='" & cmbCustomerType.Text & "'"
        If cmbProducts.Text <> "" Or cmbRegion.Text <> "" Or cmbCustomerType.Text <> "" Then
            'now extract data
            closeRS
            OpenDB
            rs.Open strSQL, cnn, adOpenKeyset, adLockOptimistic
            If rs.RecordCount > 0 Then
                'Now putting the data on the sheet
                ActiveCell.CopyFromRecordset rs
                MsgBox "I was not able to find any matching records.", vbExclamation + vbOKOnly
            'Now getting the totals using Query
            If cmbProducts.Text <> "" And cmbRegion.Text <> "" And cmbCustomerType.Text <> "" Then
                strSQL = "SELECT Count([data$].[Call ID]) AS [CountOfCall ID], [data$].[Resolved] " & _
                " FROM [Data$] WHERE ((([Data$].[Product]) = '" & cmbProducts.Text & "' ) And " & _
                " (([Data$].[Region]) =  '" & cmbRegion.Text & "' ) And (([Data$].[Customer Type]) =  '" & cmbCustomerType.Text & "' )) " & _
                " GROUP BY [data$].[Resolved];"
                closeRS
                OpenDB
                    Range("L6").CopyFromRecordset rs
                    Range("L6:M7").Clear
                    MsgBox "There was some issue getting the totals.", vbExclamation + vbOKOnly
    Private Sub cmdUpdateDropDowns_Click()
        strSQL = "Select Distinct [Product] From [data$] Order by [Product]"
        closeRS
        OpenDB
        cmbProducts.Clear
            Do While Not rs.EOF
                cmbProducts.AddItem rs.Fields(0)
                rs.MoveNext
            Loop
            MsgBox "I was not able to find any unique Products.", vbCritical + vbOKOnly
        strSQL = "Select Distinct [Region] From [data$] Order by [Region]"
        closeRS
        OpenDB
        cmbRegion.Clear
            Do While Not rs.EOF
                cmbRegion.AddItem rs.Fields(0)
                rs.MoveNext
            Loop
            MsgBox "I was not able to find any unique Region(s).", vbCritical + vbOKOnly
        strSQL = "Select Distinct [Customer Type] From [data$] Order by [Customer Type]"
        closeRS
        OpenDB
            Do While Not rs.EOF
                cmbCustomerType.AddItem rs.Fields(0)
                rs.MoveNext
            Loop
            MsgBox "I was not able to find any unique Customer Type(s).", vbCritical + vbOKOnly
    Moderator
    Jul 2012
    Here they are.
    1st clears all
    2nd fills CB's
    3rd gets desired data
        'clear the data
        cmbProducts.Clear
        cmbRegion.Clear
        With Sheets("View")
            .Visible = True
        sn = Sheets("data").Range("C3:E472")
        For j = 1 To 3
            With CreateObject("System.Collections.ArrayList")
                For jj = 1 To UBound(sn, 1)
                    If sn(jj, j) <> vbNullString Then
                        If Not .Contains(CStr(sn(jj, j))) Then .Add CStr((sn(jj, j)))
            .Sort
            Choose(j, cmbProducts, cmbRegion, cmbCustomerType).List = Application.Transpose(.toarray)
            With rngTarget
                For i = 1 To 3
                .AutoFilter
    Mar 2012
    Thanks for your replay but following codes are giving compile and syntax error
            With rngTarget
                For i = 1 To 3
                .AutoFilter
    Moderator
    Jul 2012
    Works fine for me.
    Mar 2012
    Thanks Bakerman , it is working fine now
  1. Shorten VBA Code By Removing Redundant Superfluous Code
    Last Post: 08-15-2013, 09:09 PM
  2. SQL output from Excel VBA macro
    By goldenbutter in forum Excel Help
    Last Post: 05-07-2013, 08:07 PM
  3. Replies: 2
    Last Post: 11-17-2011, 07:49 PM
  4. Execute SQL From Excel (VBA)
    By Mechanic in forum Excel and VBA Tips and Tricks
    Last Post: 10-02-2011, 04:30 PM
  5. Execute SQL From Excel (VBA)
    By Mechanic in forum Excel Help
    Last Post: 05-13-2011, 10:27 AM
