Thread: Enable And Disable Controls Based On Selection In Previous Combo Box
    Here's what I've added to your code
    Private Sub ComboBox1_Change()
        ComboBox2.Enabled = ComboBox1.Text <> ""
    Private Sub ComboBox2_Change()
        ComboBox3.Enabled = ComboBox2.Text <> ""
    Private Sub ComboBox3_Change()
        Dim lngCol As Long
        With Worksheets("sample")
            lngCol = .Rows(2).Find(What:=Me.ComboBox3.Text, lookAt:=xlWhole).Column
            Me.ComboBox4.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol).End(xlUp).Row).Offset(, lngCol - 1).Value2
            Me.ComboBox5.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol + 1).End(xlUp).Row).Offset(, lngCol).Value2
            Me.ComboBox6.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol + 2).End(xlUp).Row).Offset(, lngCol + 1).Value2
            Me.ComboBox7.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol).End(xlUp).Row).Offset(, lngCol - 1).Value2
            Me.ComboBox8.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol + 1).End(xlUp).Row).Offset(, lngCol).Value2
        Frame1.Enabled = UCase(ComboBox3.Text) = "INTERNAL"
        Frame2.Enabled = Not Frame1.Enabled
        ComboBox4.Text = ""
        ComboBox5.Text = ""
        ComboBox6.Text = ""
        ComboBox7.Text = ""
        ComboBox8.Text = ""
    In addition, I've also changed the style of your drop-down box to List-box instead of Combo-box. That way, user cannot 'type' anything that is not there in the list. In addition, I've also changed the Enabled property to false, and based on selection of value in the hierarchical order, the combo-boxes will get enabled.
  1. Replies: 8
    Last Post: 08-17-2013, 02:42 PM
  2. Replies: 8
    Last Post: 08-17-2013, 04:03 AM
  3. Replies: 1
    Last Post: 05-03-2013, 04:41 PM
  4. Replies: 2
    Last Post: 04-10-2013, 12:40 AM
  5. Replies: 3
    Last Post: 04-08-2012, 08:05 AM
