Thread: Fill ComboBox With Values From Corresponding Dynamic Column Based On Value Selected
    Mar 2013
    What needs to be changed in the code so that the each combobox total list is available.When selecting Userform- Internal (category) the Comboxbox Part in the userform only has 9 entries so when i select Part No. and Fault it only shows also 9 entries but there are more on the list which are not available.Can each Combobox (Part,Part No.,Fault) be able to show all the items in there list
    Paul
    Try this
    Private Sub ComboBox3_Change()
        Dim lngCol As Long
        With Worksheets("sample")
            lngCol = .Rows(2).Find(What:=Me.ComboBox3.Text, lookAt:=xlWhole).Column
            Me.ComboBox4.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol).End(xlUp).Row).Offset(, lngCol - 1).Value2
            Me.ComboBox5.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol + 1).End(xlUp).Row).Offset(, lngCol).Value2
            Me.ComboBox6.List = .Range("A4:A" & .Cells(.Rows.Count, lngCol + 2).End(xlUp).Row).Offset(, lngCol + 1).Value2
  1. Replies: 8
    Last Post: 08-17-2013, 04:03 AM
  2. Replies: 5
    Last Post: 08-10-2013, 04:15 PM
  3. Replies: 9
    Last Post: 08-02-2013, 07:55 PM
  4. Combobox with Dynamic Date Range
    Last Post: 07-21-2013, 06:14 PM
  5. Offset based on Values in Column E
    Last Post: 12-04-2012, 10:06 AM
