Thread: Shorten VBA Code By Removing Redundant Superfluous Code
    Mar 2013
    hI
    This code below i have modified to get it to work...it does work but could it be made simpler or tidied up
    Sub SubTotalize()
        With Sheets("XFLOW A")
           .Unprotect Password:="abc"
           .Range("B3:H" & .Cells(Rows.Count, 2).End(xlUp).Row).Subtotal GroupBy:=1, Function:=xlSum, TotalList:=Array(2, 3, 7), Replace:=True, PageBreaks:=False, SummaryBelowData:=True
           .Protect UserInterfaceOnly:=True, Password:="abc"
        Sub Subtotalize_1()
        With Sheets("XFLOW B")
        Sub subtotalize_2()
        With Sheets("XFLOW C")
    This could be one way to shorten it
    Sub SubTotalize()
       Dim var, strarrSheetNames() As String
       strarrSheetNames = Split("XFLOW A,XFLOW B,XFLOW C", ",")
       For Each var In strarrSheetNames
            With Sheets(var)
        Next var
    Mar 2013
    Thank you
    I still have an error when I select Daily Total button on XFLOW A sheet.It still performs the totals but pops up a error message.I think the error could be that both XFLOW B & C sheets are empty of data.
    On the attached sample if the Daily Total button is pressed it will show the error.
    Can the sheets all have the Daily Total option but work independent of each other.Example would be that XFLOW A & B might get data daily but XFLOW C may get data every second or third day..
    Paul
  1. Excel VBA Code to Add New Sheets
    By cdurfey in forum Excel Help
    Last Post: 06-25-2013, 08:05 AM
  2. Removing unused Cell styles - need an efficient code
    By siddharthsindhwani in forum Excel Help
    Last Post: 04-15-2013, 07:12 AM
  3. VBA Code to extract subtotals
    Last Post: 12-02-2012, 01:15 PM
  4. VBA Code to Extract data
    Last Post: 07-24-2012, 11:37 PM
  5. VBA Code to Clear the Immediate Window.
    By technicalupload in forum Excel and VBA Tips and Tricks
    Last Post: 09-02-2011, 03:04 PM
