Thread: Formula for break up score
    Aug 2013
    I have 2 columns one with yes,no answers and the corresponding category.The combined score of the yes,no answers are displayed in the cell "E1".
    I want to display the break up score of the individual categories i.e. A,B,C separately also.
    I want to perform this action without using the filter.
    (in the attached sheet the score for category A is 100%)
    Thank you.
    Aplly below formula with CSE (Ctrl + Shift + Enter) as it is an array formula
    =SUM(N(($E$4:$E$21=$G1) * ($D$4:$D$21="Yes")))/SUM(N(($E$4:$E$21=$G1)*($D$4:$D$21 = {"Yes","No"})))
    and drag this formula till value "C" in column G
    If it is not working then could you please tell us how you are calculating indivisual score.
    Aug 2013
    Quote Originally Posted by LalitPandey87 View Post
    Thanks a lot ...that helped me a lot.
