Just made the necessary correction to your specific need, and didn't really look at the formatting of the code. Use this for the submit button
In addition, there's a fault with your listbox getting refreshed. The items has to be cleared first, before loading again with other criterias via the combobox. For that, I've added one line in this routineCode:Private Sub BtnSubmit_Click() Dim wsS As Worksheet Dim wsR As Worksheet Application.ScreenUpdating = False Dim irow As Long, lngLoop As Long Set wsS = Worksheets("Resultant") 'find first row in database irow = wsS.Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Row With wsS For lngLoop = 0 To Me.ListStaIncNo.ListCount - 1 .Range("A" & irow + lngLoop).Value = Trim(Me.BxStaDistrict.Value) .Range("B" & irow + lngLoop).Value = Trim(Me.BxStaTown.Value) .Range("C" & irow + lngLoop).Value = Trim(Me.BxStaName.Value) .Range("D" & irow + lngLoop).Value = Me.ListStaIncNo.List(lngLoop) .Range("E" & irow + lngLoop).Value = Date .Range("F" & irow + lngLoop).Value = Time .Range("G" & irow + lngLoop).Value = Environ$("USERNAME") Next lngLoop End With MsgBox "Data succesfully saved to database" Application.StatusBar = False Application.ScreenUpdating = True End Sub
And here's the file.Code:Private Sub BxStaName_AfterUpdate() Dim Cl As Range Dim ClAddress As String With Me With Sheets("Source") Set rSource = .Range(.Cells(1, 4), .Cells(.Rows.Count, 1).End(xlUp)) End With 'if no selection in OIC quit If .BxStaName.ListIndex < 0 Then Exit Sub Set Cl = rSource.Find(Me.BxStaName.Value, LookIn:=xlValues) If Not Cl Is Nothing Then ClAddress = Cl.Address Me.ListStaIncNo.Clear Do .ListStaIncNo.AddItem Cl.Offset(0, 1).Value Set Cl = rSource.FindNext(Cl) Loop While Not Cl Is Nothing And Cl.Address <> ClAddress End If End With End Sub
By the way, hope you've read the guidelines about forum cross posting.
