Results 1 to 10 of 15
Thread: Transfering Data From Userform To Sheet Under Relevant Column And Row
    Mar 2013
    I need some help please with the code transferring data from userform to sheet.The sheet will be protected == password is 1357
    The userform looks at set Number and then finds it in the sheet and transfers the data.
    Paul
    I've made some modifications to your sheet. Notice the rngToCopy named range. You can move it around if required, but just keep whatever format you need. Also, revisions in the code are as follows
        Dim i As Long
        With Worksheets("LENTICULAR-MEMBRANES")
            .Unprotect Password:="1357"
            .Protect UserInterfaceOnly:=True, Password:="1357"
        Dim lngCol As Long
        Dim ctl As Object
        For Each ctl In Me.Controls
            If ctl.Tag <> vbNullString Then
                If ctl.Value = vbNullString Then MsgBox ctl.Tag: ctl.SetFocus: Exit Sub
        With Sheets("LENTICULAR-MEMBRANES")
        lngCol = .Rows("3:3").Find(What:="SET " & ComboBox2.Text, LookAt:=xlWhole).Column
           With .Cells(.Rows.Count, lngCol).End(xlUp).Offset(1).Cells(1)
                Sheets("LENTICULAR-MEMBRANES").Range("rngToCopy").Copy .Cells(1)
                .Resize(6).Value = Application.Transpose(Array("DATE", "LENTICULARS CHANGED", "MEMBRANES CHANGED", "VARIETY", "VOLUME", TextBox2.Text))
                .Offset(, 1).Resize(5) = Application.Transpose(Array(ComboBox1.Value, ComboBox3.Value, ComboBox4.Value, ComboBox5.Value, TextBox1.Text))
            If TypeName(ctl) = "TextBox" Or TypeName(ctl) = "ComboBox" Then ctl.Value = vbNullString
    Mar 2013
    I`ve changed the layout to the data capture sheet.I have set up the sheet so data goes down the sheet for each set.With the userform can it look for the heading for the set and place the information going down the sheet.If I select C2 in the Userform Lenticular set then it places that info into C2 data capture sheet
    Paul
    Mar 2013
    This is altered to a set per sheet.On the userform depending which set selected depends on which sheet data goes...if C1 selected then data goes to C1 sheet etc..etc..
    Paul
    Mar 2013
    bump
    Here's the revised code
        Dim lngCol As Long
        Dim ctl As Object
        lngCol = .Rows("2:2").Find(What:="SET " & ComboBox2.Text, LookAt:=xlWhole).Column
                .Resize(, 6) = Array(ComboBox1.Value, ComboBox3.Value, ComboBox4.Value, ComboBox5.Value, TextBox1.Text, TextBox2.Text)
    Mar 2013
    I get an error - subscript out of range
    I think it may have to do with the sheet names....
    I changed the sheet names in code but still error
    Paul
    Moderator
    Jul 2012
    Makes sence. Where is this sheet.
    Also you use the Tag-property to check for empty objects but in not one object you've filled in the Tag-property. In this case this will never work properly.
    Mar 2013
    That sheet was removed...there are 5 sheets C1,C2,C3,C4,C5....I did enter these sheets in place of the LENTICULAR-MEMBRANES but it still gave error
    I will fill in the Tag property
    I will see how this goes
    Paul
    Moderator
    Jul 2012
    But that part of code is still in your Userform_Initialize procedure so it will always throw an error when starting-up your UF.
    The way you filled in your sheets is also wrong. I suppose you will have to use the value of your Lenticular set -object to write to the correct sheet.
    It will become something like this
        With Sheets(ComboBox2.Value)
  1. Replies: 30
    Last Post: 07-19-2013, 07:52 AM
  2. Replies: 8
    Last Post: 07-01-2013, 03:52 PM
  3. Group Pivot Data Based On Row Values In One Column
    Last Post: 10-09-2012, 11:46 PM
  4. Copy Row To A New Sheet If A Value Found In Adjacent Column
    Last Post: 08-17-2012, 05:42 PM
  5. Finding Last Used Row or Column In Excel Sheet
    Last Post: 04-14-2011, 03:17 AM
