Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Customizing Right-Click Context Menu In Excel For CommandBars Cell Row And Column
  1. #11
    Jun 2013
  2. #12
    You will not be able to trigger workbook level events across your application unless you create application level events using the WithEvents keyword.
    Paste this entire code in the ThisWorkbook class module of the Personal macro workbook, save and restart excel
    Public WithEvents App As Application
    Private Sub App_SheetBeforeRightClick(ByVal Sh As Object, ByVal Target As Range, Cancel As Boolean)
        If Target.Columns.Count = Columns.Count Then
            Call AddToCellMenu("Row")
        ElseIf Target.Rows.Count = Rows.Count Then
            Call AddToCellMenu("Column")
            Call AddToCellMenu("Cell")
    Private Sub App_WorkbookDeactivate(ByVal Wb As Workbook)
        Call DeleteFromCellMenu
    Sub AddToCellMenu(strCommandBarName As String)
        Dim ContextMenu As CommandBar
        Dim MySubMenu As CommandBarControl
        ' Delete the controls first to avoid duplicates.
        ' Set ContextMenu to the Cell context menu.
        Set ContextMenu = Application.CommandBars(strCommandBarName)
        ' Add one built-in button(Save = 3) to the Cell context menu.
        ContextMenu.Controls.Add Type:=msoControlButton, ID:=3, before:=1
        ' Add one custom button to the Cell context menu.
        With ContextMenu.Controls.Add(Type:=msoControlButton, before:=2)
            .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "ToggleCaseMacro"
            .FaceId = 59
            .Caption = "Toggle Case Upper/Lower/Proper"
            .Tag = "My_Cell_Control_Tag"
        ' Add a custom submenu with three buttons.
        Set MySubMenu = ContextMenu.Controls.Add(Type:=msoControlPopup, before:=3)
        With MySubMenu
            .Caption = "Case Menu"
            With .Controls.Add(Type:=msoControlButton)
                .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "UpperMacro"
                .FaceId = 100
                .Caption = "Upper Case"
                .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "LowerMacro"
                .FaceId = 91
                .Caption = "Lower Case"
                .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "ProperMacro"
                .FaceId = 95
                .Caption = "Proper Case"
        ' Add a separator to the Cell context menu.
        ContextMenu.Controls(4).BeginGroup = True
    Sub DeleteFromCellMenu()
        Dim ctrl As CommandBarControl
        Dim lng As Long
        Const strBarNames As String = "Cell,Column,Row"
        For lng = LBound(Split(strBarNames, ",")) To UBound(Split(strBarNames, ","))
            Set ContextMenu = Application.CommandBars(Split(strBarNames, ",")(lng))
            ' Delete the custom controls with the Tag : My_Cell_Control_Tag.
            For Each ctrl In ContextMenu.Controls
                If ctrl.ID = 3 Or ctrl.Tag = "My_Cell_Control_Tag" Then
                    ctrl.Delete
            Next ctrl
        Next lng
    Sub ToggleCaseMacro()
        Dim CaseRange As Range
        Dim CalcMode As Long
        Dim cell As Range
        Set CaseRange = Intersect(Selection, _
            Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues))
        If CaseRange Is Nothing Then Exit Sub
        With Application
            CalcMode = .Calculation
            .Calculation = xlCalculationManual
            .ScreenUpdating = False
            .EnableEvents = False
        For Each cell In CaseRange.Cells
            Select Case cell.Value
            Case UCase(cell.Value): cell.Value = LCase(cell.Value)
            Case LCase(cell.Value): cell.Value = StrConv(cell.Value, vbProperCase)
            Case Else: cell.Value = UCase(cell.Value)
        Next cell
        With Application
            .ScreenUpdating = True
            .EnableEvents = True
            .Calculation = CalcMode
    Sub UpperMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub LowerMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub ProperMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Private Sub Workbook_Open()
        Set App = Application
  3. #13
    Jul 2013
    Actually I have placed only this in ThisWorkbook
    This in a Module called Context_Menus
            .FaceId = 59
        With MySubMenu
                .FaceId = 100
                .FaceId = 91
                .FaceId = 95
        Dim lng As Long
                    ctrl.Delete
            Next ctrl
        Next lng
    And finally another module that holds the actual macros
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub UpperMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub LowerMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub ProperMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    And it works just fine in personal macro workbook.
    I believe that it will do just fine also in xlam
    Thank you very much for all the trouble you ve gone into.
    I promise to share the addin with my exras as soon as it is tested properly.
  4. #14
    Yes it should
  5. #15
    Jun 2013
    I think it would be enough to eliminate this sub to make the manu change permanent
    Private Sub Workbook_Deactivate()
  1. Replies: 4
    Last Post: 06-01-2013, 01:08 PM
  2. Highlight Active Cell’s Row and Column
  3. Replies: 7
    Last Post: 04-21-2013, 07:50 PM
  4. Lookup From Cell Range By Matching Row and Column
    Last Post: 03-07-2013, 02:02 PM
  5. Add Control To Right-Click Cell Context Menu
    Last Post: 04-17-2011, 08:04 PM
