Actually I have placed only this in ThisWorkbook
Code:Option Explicit Public WithEvents App As Application Private Sub App_SheetBeforeRightClick(ByVal Sh As Object, ByVal Target As Range, Cancel As Boolean) If Target.Columns.Count = Columns.Count Then Call AddToCellMenu("Row") ElseIf Target.Rows.Count = Rows.Count Then Call AddToCellMenu("Column") Else Call AddToCellMenu("Cell") End If End Sub Private Sub App_WorkbookDeactivate(ByVal Wb As Workbook) Call DeleteFromCellMenu End Sub Private Sub Workbook_Open() Set App = Application End Sub
This in a Module called Context_Menus
And finally another module that holds the actual macrosCode:Sub AddToCellMenu(strCommandBarName As String) Dim ContextMenu As CommandBar Dim MySubMenu As CommandBarControl ' Delete the controls first to avoid duplicates. Call DeleteFromCellMenu ' Set ContextMenu to the Cell context menu. Set ContextMenu = Application.CommandBars(strCommandBarName) ' Add one built-in button(Save = 3) to the Cell context menu. ContextMenu.Controls.Add Type:=msoControlButton, ID:=3, before:=1 ' Add one custom button to the Cell context menu. With ContextMenu.Controls.Add(Type:=msoControlButton, before:=2) .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "ToggleCaseMacro" .FaceId = 59 .Caption = "Toggle Case Upper/Lower/Proper" .Tag = "My_Cell_Control_Tag" End With ' Add a custom submenu with three buttons. Set MySubMenu = ContextMenu.Controls.Add(Type:=msoControlPopup, before:=3) With MySubMenu .Caption = "Case Menu" .Tag = "My_Cell_Control_Tag" With .Controls.Add(Type:=msoControlButton) .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "UpperMacro" .FaceId = 100 .Caption = "Upper Case" End With With .Controls.Add(Type:=msoControlButton) .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "LowerMacro" .FaceId = 91 .Caption = "Lower Case" End With With .Controls.Add(Type:=msoControlButton) .OnAction = "'" & ThisWorkbook.Name & "'!ThisWorkbook." & "ProperMacro" .FaceId = 95 .Caption = "Proper Case" End With End With ' Add a separator to the Cell context menu. ContextMenu.Controls(4).BeginGroup = True End Sub Sub DeleteFromCellMenu() Dim ContextMenu As CommandBar Dim ctrl As CommandBarControl Dim lng As Long Const strBarNames As String = "Cell,Column,Row" ' Set ContextMenu to the Cell context menu. For lng = LBound(Split(strBarNames, ",")) To UBound(Split(strBarNames, ",")) Set ContextMenu = Application.CommandBars(Split(strBarNames, ",")(lng)) ' Delete the custom controls with the Tag : My_Cell_Control_Tag. For Each ctrl In ContextMenu.Controls If ctrl.ID = 3 Or ctrl.Tag = "My_Cell_Control_Tag" Then ctrl.Delete End If Next ctrl Next lng End Sub
And it works just fine in personal macro workbook.Code:Sub ToggleCaseMacro() Dim CaseRange As Range Dim CalcMode As Long Dim cell As Range On Error Resume Next Set CaseRange = Intersect(Selection, _ Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues)) On Error GoTo 0 If CaseRange Is Nothing Then Exit Sub With Application CalcMode = .Calculation .Calculation = xlCalculationManual .ScreenUpdating = False .EnableEvents = False End With For Each cell In CaseRange.Cells Select Case cell.Value Case UCase(cell.Value): cell.Value = LCase(cell.Value) Case LCase(cell.Value): cell.Value = StrConv(cell.Value, vbProperCase) Case Else: cell.Value = UCase(cell.Value) End Select Next cell With Application .ScreenUpdating = True .EnableEvents = True .Calculation = CalcMode End With End Sub Sub UpperMacro() Dim CaseRange As Range Dim CalcMode As Long Dim cell As Range On Error Resume Next Set CaseRange = Intersect(Selection, _ Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues)) On Error GoTo 0 If CaseRange Is Nothing Then Exit Sub With Application CalcMode = .Calculation .Calculation = xlCalculationManual .ScreenUpdating = False .EnableEvents = False End With For Each cell In CaseRange.Cells cell.Value = UCase(cell.Value) Next cell With Application .ScreenUpdating = True .EnableEvents = True .Calculation = CalcMode End With End Sub Sub LowerMacro() Dim CaseRange As Range Dim CalcMode As Long Dim cell As Range On Error Resume Next Set CaseRange = Intersect(Selection, _ Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues)) On Error GoTo 0 If CaseRange Is Nothing Then Exit Sub With Application CalcMode = .Calculation .Calculation = xlCalculationManual .ScreenUpdating = False .EnableEvents = False End With For Each cell In CaseRange.Cells cell.Value = LCase(cell.Value) Next cell With Application .ScreenUpdating = True .EnableEvents = True .Calculation = CalcMode End With End Sub Sub ProperMacro() Dim CaseRange As Range Dim CalcMode As Long Dim cell As Range On Error Resume Next Set CaseRange = Intersect(Selection, _ Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues)) On Error GoTo 0 If CaseRange Is Nothing Then Exit Sub With Application CalcMode = .Calculation .Calculation = xlCalculationManual .ScreenUpdating = False .EnableEvents = False End With For Each cell In CaseRange.Cells cell.Value = StrConv(cell.Value, vbProperCase) Next cell With Application .ScreenUpdating = True .EnableEvents = True .Calculation = CalcMode End With End Sub
I believe that it will do just fine also in xlam
Thank you very much for all the trouble you ve gone into.
I promise to share the addin with my exras as soon as it is tested properly.
