Sure Patel.
Private Sub Workbook_SheetBeforeRightClick(ByVal Sh As Object, ByVal Target As Range, Cancel As Boolean)
    If Target.Columns.Count = Columns.Count Then
        Call AddToCellMenu("Row")
    ElseIf Target.Rows.Count = Rows.Count Then
        Call AddToCellMenu("Column")
        Call AddToCellMenu("Cell")
Private Sub Workbook_Deactivate()
    Call DeleteFromCellMenu
Sub AddToCellMenu(strCommandBarName As String)
    Dim ContextMenu As CommandBar
    Dim MySubMenu As CommandBarControl
    ' Delete the controls first to avoid duplicates.
    ' Set ContextMenu to the Cell context menu.
    Set ContextMenu = Application.CommandBars(strCommandBarName)
    ' Add one built-in button(Save = 3) to the Cell context menu.
    ContextMenu.Controls.Add Type:=msoControlButton, ID:=3, before:=1
    ' Add one custom button to the Cell context menu.
    With ContextMenu.Controls.Add(Type:=msoControlButton, before:=2)
        .OnAction = "'" & ThisWorkbook.Name & "'!" & "ToggleCaseMacro"
        .FaceId = 59
        .Caption = "Toggle Case Upper/Lower/Proper"
        .Tag = "My_Cell_Control_Tag"
    ' Add a custom submenu with three buttons.
    Set MySubMenu = ContextMenu.Controls.Add(Type:=msoControlPopup, before:=3)
    With MySubMenu
        .Caption = "Case Menu"
        With .Controls.Add(Type:=msoControlButton)
            .OnAction = "'" & ThisWorkbook.Name & "'!" & "UpperMacro"
            .FaceId = 100
            .Caption = "Upper Case"
            .OnAction = "'" & ThisWorkbook.Name & "'!" & "LowerMacro"
            .FaceId = 91
            .Caption = "Lower Case"
            .OnAction = "'" & ThisWorkbook.Name & "'!" & "ProperMacro"
            .FaceId = 95
            .Caption = "Proper Case"
    ' Add a separator to the Cell context menu.
    ContextMenu.Controls(4).BeginGroup = True
Sub DeleteFromCellMenu()
    Dim ctrl As CommandBarControl
    Dim lng As Long
    Const strBarNames As String = "Cell,Column,Row"
    For lng = LBound(Split(strBarNames, ",")) To UBound(Split(strBarNames, ","))
        Set ContextMenu = Application.CommandBars(Split(strBarNames, ",")(lng))
        ' Delete the custom controls with the Tag : My_Cell_Control_Tag.
        For Each ctrl In ContextMenu.Controls
            If ctrl.ID = 3 Or ctrl.Tag = "My_Cell_Control_Tag" Then
                ctrl.Delete
        Next ctrl
    Next lng
Sub ToggleCaseMacro()
    Dim CaseRange As Range
    Dim CalcMode As Long
    Dim cell As Range
    Set CaseRange = Intersect(Selection, _
        Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues))
    If CaseRange Is Nothing Then Exit Sub
    With Application
        CalcMode = .Calculation
        .Calculation = xlCalculationManual
        .ScreenUpdating = False
        .EnableEvents = False
    For Each cell In CaseRange.Cells
        Select Case cell.Value
        Case UCase(cell.Value): cell.Value = LCase(cell.Value)
        Case LCase(cell.Value): cell.Value = StrConv(cell.Value, vbProperCase)
        Case Else: cell.Value = UCase(cell.Value)
    Next cell
    With Application
        .ScreenUpdating = True
        .EnableEvents = True
        .Calculation = CalcMode
Sub UpperMacro()
    Dim cell As Range
    With Application
    Next cell
    With Application
Sub LowerMacro()
    Dim cell As Range
    With Application
    Next cell
    With Application
Sub ProperMacro()
    Dim cell As Range
    With Application
    Next cell
    With Application
