Results 1 to 10 of 15
Thread: Customizing Right-Click Context Menu In Excel For CommandBars Cell Row And Column
    Jul 2013
    I have compiled a set of macros and user forms (lets call them extras) and I have managed to place them in the context menu of the cell.
    I have used the logic described in this article. Check the code of AddToCellMenu and DeleteFromCellMenu Subs.
    It worked on one or more cells perfectly, however I realized that when I right clicked a row or column the context menu did not have the extras.
    It applied on one or more cells cause I have used
    Dim ContextMenu As CommandBar
    Set ContextMenu = Application.CommandBars("Cell")
    but in order to make it work for rows context menu I have to use
    Set ContextMenu = Application.CommandBars("Rows")
    and for columns context menu use
    Set ContextMenu = Application.CommandBars("Columns")
    I would like to combine them somehow so as not to repeat unnecessarily lines of code for each context menu so as to apply the extras, especially if you think that they are in several submenus also...
    Please advise... and thank you in advance for any idea.
    Take out the Workbook_Activate event. And use the code below to which I've made some modifications
    Private Sub Workbook_SheetBeforeRightClick(ByVal Sh As Object, ByVal Target As Range, Cancel As Boolean)
        If Target.Columns.Count = Columns.Count Then
            Call AddToCellMenu("Row")
        ElseIf Target.Rows.Count = Rows.Count Then
            Call AddToCellMenu("Column")
            Call AddToCellMenu("Cell")
    Private Sub Workbook_Deactivate()
        Call DeleteFromCellMenu
    Sub AddToCellMenu(strCommandBarName As String)
        Dim MySubMenu As CommandBarControl
        ' Delete the controls first to avoid duplicates.
        ' Set ContextMenu to the Cell context menu.
        Set ContextMenu = Application.CommandBars(strCommandBarName)
        ' Add one built-in button(Save = 3) to the Cell context menu.
        ContextMenu.Controls.Add Type:=msoControlButton, ID:=3, before:=1
        ' Add one custom button to the Cell context menu.
        With ContextMenu.Controls.Add(Type:=msoControlButton, before:=2)
            .OnAction = "'" & ThisWorkbook.Name & "'!" & "ToggleCaseMacro"
            .FaceId = 59
            .Caption = "Toggle Case Upper/Lower/Proper"
            .Tag = "My_Cell_Control_Tag"
        ' Add a custom submenu with three buttons.
        Set MySubMenu = ContextMenu.Controls.Add(Type:=msoControlPopup, before:=3)
        With MySubMenu
            .Caption = "Case Menu"
            With .Controls.Add(Type:=msoControlButton)
                .OnAction = "'" & ThisWorkbook.Name & "'!" & "UpperMacro"
                .FaceId = 100
                .Caption = "Upper Case"
                .OnAction = "'" & ThisWorkbook.Name & "'!" & "LowerMacro"
                .FaceId = 91
                .Caption = "Lower Case"
                .OnAction = "'" & ThisWorkbook.Name & "'!" & "ProperMacro"
                .FaceId = 95
                .Caption = "Proper Case"
        ' Add a separator to the Cell context menu.
        ContextMenu.Controls(4).BeginGroup = True
    Sub DeleteFromCellMenu()
        Dim ctrl As CommandBarControl
        Dim lng As Long
        Const strBarNames As String = "Cell,Column,Row"
        For lng = LBound(Split(strBarNames, ",")) To UBound(Split(strBarNames, ","))
            Set ContextMenu = Application.CommandBars(Split(strBarNames, ",")(lng))
            ' Delete the custom controls with the Tag : My_Cell_Control_Tag.
            For Each ctrl In ContextMenu.Controls
                If ctrl.Tag = "My_Cell_Control_Tag" Then
                    ctrl.Delete
            Next ctrl
        Next lng
        ' Delete the custom built-in Save button.
        While Not ContextMenu.FindControl(ID:=3) Is Nothing
            ContextMenu.FindControl(ID:=3).Delete
        Wend
    Jun 2013
    Very interesting, can you paste the whole code or attach a sample file ? some subs are missing
    Sure Patel.
            .FaceId = 59
        With MySubMenu
                .FaceId = 100
                .FaceId = 91
                .FaceId = 95
        Dim lng As Long
                If ctrl.ID = 3 Or ctrl.Tag = "My_Cell_Control_Tag" Then
                    ctrl.Delete
            Next ctrl
        Next lng
    Sub ToggleCaseMacro()
        Dim CaseRange As Range
        Dim CalcMode As Long
        Dim cell As Range
        Set CaseRange = Intersect(Selection, _
            Selection.Cells.SpecialCells(xlCellTypeConstants, xlTextValues))
        If CaseRange Is Nothing Then Exit Sub
        With Application
            CalcMode = .Calculation
            .Calculation = xlCalculationManual
            .ScreenUpdating = False
            .EnableEvents = False
        For Each cell In CaseRange.Cells
            Select Case cell.Value
            Case UCase(cell.Value): cell.Value = LCase(cell.Value)
            Case LCase(cell.Value): cell.Value = StrConv(cell.Value, vbProperCase)
            Case Else: cell.Value = UCase(cell.Value)
        Next cell
        With Application
            .ScreenUpdating = True
            .EnableEvents = True
            .Calculation = CalcMode
    Sub UpperMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub LowerMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Sub ProperMacro()
        Dim cell As Range
        With Application
        Next cell
        With Application
    Jun 2013
    Thanks for the code.
    I think ther'is a bug , now I have this right clic menu , without added Items, but with many save items, how can I reset it ?
    Patel, yes you are right. I missed that one. I've corrected that above.
    Jul 2013
    Sorry but.... which code is the correct?
    The one in post #4
    Jun 2013
    Ok, thank you, it works well now.
    Jul 2013
    I have managed to make the adjustments needed for my set of macros and extra options needed in the context menu and it works if I make it on an xlsm file.
    However since I needed this to work on all the instances of excel, I thought that I should place it on personal macro workbook or at least save the xlsm as add-in (xlam).
    Sadly none of these options worked so wherever I right-click nothing happens. In none of the 2 options available...
    Any suggestion??
    Thanks again in advance!
  1. Replies: 4
    Last Post: 06-01-2013, 01:08 PM
  2. Highlight Active Cell’s Row and Column
  3. Replies: 7
    Last Post: 04-21-2013, 07:50 PM
  4. Lookup From Cell Range By Matching Row and Column
    Last Post: 03-07-2013, 02:02 PM
  5. Add Control To Right-Click Cell Context Menu
    Last Post: 04-17-2011, 08:04 PM
