Results 1 to 10 of 21
Thread: VBA To Display Pop Up Alert When Duplicate Entry Is Made
    Move the code into workbook module. Like
    Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
        Dim rFound As Excel.Range
        Dim rCount  As Long
        Select Case UCase$(Sh.Name)
            Case "USED CONTRACTS", "ARCHIVE"    '<<<<< add more sheets
                If Target.Column = 2 Then
                    rCount = Application.WorksheetFunction.CountIf(Sh.UsedRange.Columns(2), Target.Value)
                    If rCount > 1 Then
                        Set rFound = Sh.Range("B:B").Find(What:=Target.Value, MatchCase:=False, Lookat:=xlWhole)
                        If Not rFound Is Nothing Then
                            If MsgBox("The registration Number  " & Target.Value & _
                            "    has been found in row  " & rFound.Row & vbCrLf & vbCrLf & _
                            "Do you want to view this entry?", vbQuestion + vbYesNo, "Confirm") = vbYes Then
                                 '// You might want to delete the 'new' entry/entire line here
                                 '// otherwise the suplicate remains.
                                 '// Application.EnableEvents = False
                                 '// Target.Value = vbNullString
                                 '// Application.EnableEvents = True
                                 '// Application.Goto rFound, True
                                rFound.Activate
    Edit: Code edited.
  1. Code to pop up message when there is a variance
    Last Post: 08-13-2013, 12:45 PM
  2. Replies: 6
    Last Post: 05-16-2013, 09:56 AM
  3. Replies: 7
    Last Post: 04-22-2013, 01:41 PM
  4. Save Workbook For Each Change Made In A Range
    By Stalker in forum Excel Help
    Last Post: 03-22-2013, 08:54 PM
  5. Macro for Contra entry
    By ravichandavar in forum Excel Help
    Last Post: 08-12-2012, 09:47 PM
