Results 11 to 20 of 21
Thread: VBA To Display Pop Up Alert When Duplicate Entry Is Made
  1. #11
    Jun 2013
    attach the current file again
  2. #12
    May 2013
    The file with three sheets and very little data is over 323kb so i have zipped it
    Peter
    The code I provided is not there in the workbook. I edited my original code. So you can copy that code and paste in the Workbook module. It is working fine here.
    BTW, End Sub is missing in your workbook_open event code.
  4. #14
    May 2013
    Thanks for that i must have deleted the en sub!
    the pop up now works on every sheet, but i was after it searching all sheets so that if i was entering a reg in contract sheet but the reg had been archived
    it would inform me that it was dulicated in that sheet so i could copy that data back into the live contract page
    Peter
  5. #15
    OK. Try this
    Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
        Dim rFound  As Excel.Range
        Dim rCount  As Long
        Dim Shts    As Variant
        Dim i       As Long
        Shts = Array("USED CONTRACTS", "ARCHIVE", "CONTRACTS")
        Select Case UCase$(Sh.Name)
            Case "USED CONTRACTS", "ARCHIVE", "CONTRACTS"   '<<<<< add more sheets (in upper case)
                If Target.Column = 2 Then
                    For i = LBound(Shts) To UBound(Shts)
                        rCount = rCount + Application.WorksheetFunction.CountIf(Worksheets(Shts(i)).UsedRange.Columns(2), Target.Value)
                        If rCount > 1 Then
                            Set rFound = Worksheets(Shts(i)).UsedRange.Columns(2).Find(What:=Target.Value, MatchCase:=False, Lookat:=xlWhole)
                            If Not rFound Is Nothing Then
                                If MsgBox("The registration Number  " & Target.Value & _
                                "    has been found in row  " & rFound.Row & vbCrLf & vbCrLf & _
                                "Do you want to view this entry?", vbQuestion + vbYesNo, "Confirm") = vbYes Then
                                     '// You might want to delete the 'new' entry/entire line here
                                     '// otherwise the suplicate remains.
                                     '// Application.EnableEvents = False
                                     '// Target.Value = vbNullString
                                     '// Application.EnableEvents = True
                                    Application.Goto rFound, True
                                    'rFound.Activate
                                    Exit For
    Again in thisworkbook module.
  6. #16
    May 2013
    HI
    Sorry to be a pain
    It does not seem to work at all now?
    I have nothing in (contracts,used contracts,archive)
    row deletion code in (this workbook)
    your new code in module 1
    Is this correct?
  7. #17
    May 2013
    If i put this in the workbook and not in module 1 it will work as before find duplications in the sheet i am in but not find a reg in archive
    if i am in the contracts sheet
    i have notice now that if there is a reg in the archive sheet and i type it in the contract sheet it finds its self on the contract sheet, so it is seeing the duplicated reg but not saying which sheet it is on and not taking you to that sheet.
    Also when it locates a duplicate in the same sheet and you press ok to go to it .the sheet moves over one column so you cant see the customer name
    Thanks for looking
    Peter
  8. #18
    It works fine here.
    PFA.
  9. #19
    May 2013
    I have tried your test file and it finds the regs on other sheets but it also finds itself on the sheet your on?
    Cheers
    Peter
  10. #20
    Is this what you are after ?
        Dim rCount  As Long
        Dim Shts    As Variant
        Dim i       As Long
        Shts = Array("CONTRACTS", "USED CONTRACTS", "ARCHIVE")
            Case "CONTRACTS", "USED CONTRACTS", "ARCHIVE"   '<<<<< add more sheets (in upper case)
                        If rCount And rFound Is Nothing Then
                        If rCount > 1 Then
                                    "    has been found in row  " & rFound.Row & vbLf & "on Sheet '" & rFound.Parent.Name & "'" & vbCrLf & vbCrLf & _
                                'rFound.Activate
                                Exit For
  1. Code to pop up message when there is a variance
    Last Post: 08-13-2013, 12:45 PM
  2. Replies: 6
    Last Post: 05-16-2013, 09:56 AM
  3. Replies: 7
    Last Post: 04-22-2013, 01:41 PM
  4. Save Workbook For Each Change Made In A Range
    By Stalker in forum Excel Help
    Last Post: 03-22-2013, 08:54 PM
  5. Macro for Contra entry
    By ravichandavar in forum Excel Help
    Last Post: 08-12-2012, 09:47 PM
