Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: VBA To Display Pop Up Alert When Duplicate Entry Is Made
    May 2013
    I have attached a sample spread sheet with a vba code to detect duplicated reg numbers and take you to the original entry
    unfortunatley it also shows the warning on unique enteries as well,could anybody help me with a solution to stop this happening
    thanks Peter
    Jun 2013
    try this code
        Dim rFound As Excel.Range
        If Target.Column = 2 Then
          NewVal = Target.Value
          Application.EnableEvents = False
          Application.Undo 'the previous value is re-established.
          Set rFound = Range("B:B").Find(What:=NewVal, MatchCase:=False, Lookat:=xlWhole)
          If Not rFound Is Nothing Then
             If MsgBox("The registration Number  " & Target.Value & _
                "    has been found in row  " & rFound.Row & vbCrLf & vbCrLf & _
                "Do you want to view this entry?", vbQuestion + vbYesNo, "Confirm") = vbYes Then
                    rFound.Activate
                    Target.Value = NewVal
                    Application.EnableEvents = True
    Try this code.
        Dim rCount  As Long
            rCount = Application.WorksheetFunction.CountIf(Me.UsedRange.Columns(2), Target.Value)
            If rCount > 1 Then
                Set rFound = Range("B:B").Find(What:=Target.Value, MatchCase:=False, Lookat:=xlWhole)
                         '// You might want to delete the 'new' entry/entire line here
                         '// otherwise the suplicate remains.
                         '// Application.EnableEvents = False
                         '// Target.Value = vbNullString
                         '// Application.EnableEvents = True
                         '// Application.Goto rFound, True
                        rFound.Activate
    May 2013
    How can i amend the code so that it would also check in two other sheets one called used contracts and one called archive and take you there
    if possible
    May 2013
    Thanks guys
    thats spot on the first could did not pick up the reg in the warning bos but the second did
    once any many thanks
    Peter
    Move the code into workbook module. Like
    Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
        Dim rCount  As Long
        Select Case UCase$(Sh.Name)
            Case "USED CONTRACTS", "ARCHIVE"    '<<<<< add more sheets
                    rCount = Application.WorksheetFunction.CountIf(Sh.UsedRange.Columns(2), Target.Value)
                    If rCount > 1 Then
                        Set rFound = Sh.Range("B:B").Find(What:=Target.Value, MatchCase:=False, Lookat:=xlWhole)
                                rFound.Activate
    Edit: Code edited.
    Jun 2013
    otherwise you have to copy the code on the other sheet
    May 2013
    I have tried to put the code in the workbook but an error comes up (method of data member not found) and highlights me.used range.
    I have also tried to add the code in each sheet but still no joy, am i doing somthing wrong?
    Peter
    Replace Me with Sh
    May 2013
    hI
    I have replaced that thanks the error has now gone, however it still will not locate a duplicated reg in either used or archive sheet?
    i have placed it in a module on the workbook.
    Would it also be able to say found reg ...... on row .... in sheet name?
    Thanks Peter
  1. Code to pop up message when there is a variance
    Last Post: 08-13-2013, 12:45 PM
  2. Replies: 6
    Last Post: 05-16-2013, 09:56 AM
  3. Replies: 7
    Last Post: 04-22-2013, 01:41 PM
  4. Save Workbook For Each Change Made In A Range
    By Stalker in forum Excel Help
    Last Post: 03-22-2013, 08:54 PM
  5. Macro for Contra entry
    By ravichandavar in forum Excel Help
    Last Post: 08-12-2012, 09:47 PM
