Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Excel Formula To Distribute An Amount To Different Parts With Different Limits
  1. #11
    Apr 2011
    sorry, somehow i did not see the post #5 it was just visible to me now. i cant figure out why i could not see it. however, i have tried it, and
    i think i missed a point here recovery always will be amount-first layer deductible, means if the amount is 58,504,967 then total recovery will be 58,504,967-15,000,000=43,504,967 from 1st till 2nd layer (1st will get max 15,000,000 and second 43,504,967-15,000,000=28,504,967 and the rest of the layers will be 0.
    excel_learner
    (Using XL 2007 & 2010)
    -------Learning never stops!
  2. #12
    In the file I had attached in post #5, use
    C5=MIN(B5-C$3,C$3) and drag down
    D5=MIN($B5-SUM($C$3,$C5:C5),D$3) and drag down and across
  3. #13
    Apr 2011
    Thank you so much, it works great
    excel_learner
  1. Replies: 1
    Last Post: 07-23-2013, 10:43 PM
  2. Random Time Between Fixed Lower And Upper Limits
    By papabill in forum Excel Help
    Last Post: 07-22-2013, 05:01 PM
  3. Custom Charts in Excel :: Comparison RAG Chart Showing Tolerance Limits
    Last Post: 06-13-2013, 09:40 PM
  4. Distribute ranges as per Plan
    Last Post: 12-17-2012, 10:40 PM
  5. Amount to Words [EXCEL 2007]
    By msiyab in forum Excel Help
    Last Post: 06-10-2012, 03:14 PM
