Thread: Target.Value help in Worksheet_Change
    May 2013
    Hello,
    I'm having an issue with some code in my Worksheet_Change event. Whenever I select several cells and fill down or right, or whenever I delete the contents of merged cells (which the macro unmerges automatically), I get a debug error because of a type mismatch. I would assume Target.Value is a variant (as it could be a string or number) and therefore can accept any data type, but I'm guessing it's not one because I keep getting the errors.
    Here is an example of my code. If you guys could tell me how to stop getting the type mismatch error, I would be very thankful.
        Select Case Target.value
            Case "R", "r"
                Target.Interior.Color = RGB(255, 0, 0)  'background is red
                Target.Font.Color = RGB(0, 255, 255)    'font color is cyan
            Case "G", "g"
                Target.Interior.Color = RGB(0, 255, 0)  'background is green
                Target.Font.Color = RGB(255, 0, 255)    'font color is magenta
            Case "B", "b"
                Target.Interior.Color = RGB(0, 0, 255)  'background is blue
                Target.Font.Color = RGB(255, 255, 0)    'font color is yellow
                Range(Target.Address, Cells(Target.row + 1, Target.Column + 1)).Merge
            Case "" '
                Target.Interior.ColorIndex = 0
                Target.Font.Color = RGB(0, 0, 0)
                Range(Target.Address).UnMerge
    Jun 2013
    what's the goal of
            Case "" '
    add this line above the Select case statement
    If Target.Cells.Count > 1 Then Exit Sub
    this will allow to exit the sub while working on multiple cells.
    May 2013
    Quote Originally Posted by patel View Post
    what's the goal of
            Case "" '
    Well, Case "" represents the deletion of cell contents, so it's supposed to set the background to no color and the font color to black, and then it's supposed to unmerge the cells. The background and font colors are changing only on the already unmerged cells, though.
    Thank you, that worked.
  1. Conditional Insert Query Based on Data in Target Table
    Last Post: 06-23-2013, 04:24 PM
  2. Worksheet_Change event
    By Excelfun in forum Excel Help
    Last Post: 11-21-2012, 07:24 AM
  3. Event target range
    By bobkap in forum Excel Help
    Last Post: 09-13-2012, 05:34 AM
  4. Excel to Excel Data transfer without opening any of the files(source or target)
    By Transformer in forum Excel and VBA Tips and Tricks
    Last Post: 08-22-2012, 10:57 AM
