Results 1 to 10 of 10
Thread: Random Time Between Fixed Lower And Upper Limits
    Nov 2012
    I've been able to create random numbers, but I cannot create random times. For example, I want to create a schedule of training and use random times to call the group together (between 6:30 and 9:00, or between 11:45 and 2:00). Is there any formula to do this?
    Jun 2013
    Quote Originally Posted by papabill View Post
    Have you tried creating random numbers and adding them to your start times with TimeSerial() ?
    Edit: Tested it, and it was better to use just one random number and figure the minutes between your times. 6:30 to 9:00 would be 150minutes.
    Edited code:
    Dim randomminute As Integer
    Dim StartTime1 As String
        StartTime1 = "6:30 AM"
        randomminute = Int((150 - 0 + 1) * Rnd + 0)
        ActiveCell.Value = StartTime1
        ActiveCell.Value = ActiveCell.Value + TimeSerial(0, randomminute, 0)
        ActiveCell.NumberFormat = "hh:mm am/pm"
    testingcode, you could limit the lines to this
    ActiveCell.Value = TimeValue("06:30:00") + TimeSerial(0, Int((150 - 0 + 1) * Rnd + 0), 0)
    However, OP wanted to include two time ranges.
    Here's one way to do that
            Randomize
            If Rnd > 0.5 Then
                ActiveCell.Value = (TimeValue("09:00:00") - TimeValue("06:30:00") + 0.0001) * Rnd + TimeValue("06:30:00")
                ActiveCell.Value = (TimeValue("14:00:00") - TimeValue("11:45:00") + 0.0001) * Rnd + TimeValue("11:45:00")
    Having said that, since the original request was for a formula, this should suffice
    =IF(RAND()<0.5,TIME(6,RANDBETWEEN(30,180),0),TIME( 11,RANDBETWEEN(45,180),0))
    Jun 2013
    Still learning. Also didn't see the formula part
    Nov 2012
    That seems to work well, but the products are very random. I still need to control them.
    How do I put it so it will give me times between 6 - 9am, 11am - 2pm, 6pm - 8pm, and 11pm - 12:30am
    Day          Stretches     Running warmups     Pulls          Pushes
    Mon          6:30am            11:15am            6:15pm      11:30pm
    Tue          8:00am             1:30pm            7:20pm      11:15pm
    Wed         etc.                   etc.                etc.           etc.
    Times are changing due to other activities and training.
    Jun 2013
    Are you wanting 6-9am in the Stretches column, 11am-2pm in the Running warmups column, ect..?
    If so, then you can just use the
    =TIME(6,RANDBETWEEN(0,180),0)
    in the correct column and adjust the bolded numbers to whatever time frame is needed for that column. The example formula above would be for the Streches column.
    Nov 2012
    Quote Originally Posted by testingcode View Post
    Can you explain something for me? I understand MOST of the formula, but not all. =TIME(6,RANDBETWEEN(0,180),0)
    I understand the 6 (6 oclock) and the 180 (180 minutes-three hours past 6 = 9), but what about the 0 in (0,180)?
    Jun 2013
    RANDBETWEEN(0,180) means that it picks a random number between 0 and 180. 0 is your lower bound and 180 is your upper. For example, a RANDBETWEEN(10,180) would never return a 1, 2, or 3, ect..
    Nov 2012
    Thanks to all you for the help. Now I can create a good schedule.
  1. Custom Charts in Excel :: Comparison RAG Chart Showing Tolerance Limits
    Last Post: 06-13-2013, 09:40 PM
  2. Calculate Time Difference Between Time In HH:MM
    By Stalker in forum Excel Help
    Last Post: 03-28-2013, 03:27 PM
  3. Fixed asset Register
    Last Post: 11-14-2012, 10:20 AM
  4. Reverse name in excel with upper case,edit formula
    By shrinivasmj in forum Excel Help
    Last Post: 09-11-2012, 01:31 PM
  5. Spreading a time range (shift time, etc) in columns.
    Last Post: 08-23-2011, 11:45 AM
