Thread: ONE CELL AS RANGE IN VBA INSIDE AN IF STATEMENT
    Banned
    May 2013
    Please help me out to figure out what is the problem. There is no error said but there is one problem that there is no data generated when it is runned. The unclassified tab do contain a data.
    If O24 = "AMERICAS" Or O24 = "americas" Then
        Sheets("UNCLASSIFIED").Select
        Columns("D:D").Delete
        Columns("A:C").Select
        Selection.Copy
        Sheets("CLASSIFIED-americas").Select
        Range("A:C").Select
        Selection.PasteSpecial Paste:=xlPasteFormulas, Operation:=xlNone, _
            SkipBlanks:=False, Transpose:=False
        Columns("D:P").Select
        Selection.Copy
        Range("K:W").Select
        Range("A1").Select
        Sheets("INSTRUCTIONS").Activate
        If O24 = "RRRS" Or O24 = "rrrs" Then
        Selection.Copy
        Sheets("CLASSIFIED-RRRS").Select
        Range("A:C").Select
        Selection.Copy
        Range("K:W").Select
        Range("A1").Select
        If O24 = "RRR" And O24 = "RRR" Then
        Selection.Copy
        Sheets("CLASSIFIED-RRR").Select
        Range("A:C").Select
        Selection.Copy
        Range("K:W").Select
        Range("A1").Select
    Thank you and Good luck!
    Jeff
    It should be
    If ucase$(range("O24").value) = "AMERICAS" Then
  1. Replies: 8
    Last Post: 04-29-2013, 08:36 PM
  2. VBA Procedure for nested if statement.
    By _google in forum Excel Help
    Last Post: 02-08-2013, 10:16 PM
  3. Split Function That Ignores Delimiters Located Inside Quote Marks
    Last Post: 09-21-2012, 10:27 PM
  4. Replies: 0
    Last Post: 09-07-2012, 09:10 PM
  5. Get last Filled Cell address in a Range.
    Last Post: 03-24-2012, 01:08 AM
