Thread: Embed an Excel Chart into PowerPoint - VBA
    May 2012
    Question Embed an Excel Chart into PowerPoint - VBA
    I am trying to copy a ChartObject created in a workbook sheet and paste it into a powerpoint 2010 slide, such that it becomes a standalone Excel Chart with data (embedded).
    When i do it manually i.e :
    1. Copy ChartObject present in WorkSheet
    2. Goto Powerpoint Slide
    3. Click PasteSpecial & select "Use Destination Theme & Embed Workbook (H)".
    4. Right-click the ChartObject in Powerpoint & click "Edit Data".
    Then i get a new standalone workbook with Title "Chart in Microsoft Excel", that shows the Chart as well as data. I have not been able to replicate this scenario where i get a new standalone workbook with Title "Chart in Microsoft Excel" using Excel VBA. Can someone help?
    Assuming there is a simple column chart on the sheet, here is the code:
    PHP Code:
    Option Explicit
    Sub doit
    Dim Temp As Workbook
    Dim Rng
    As Range
    Dim ChtObj
    As ChartObject
    With ThisWorkbook
    .Sheets(1)
    Set ChtObj = .ChartObjects(1)
    With ChtObj
    .Copy
        End With
        Dim ppapp
    As Object
        Dim pppres
    As Object
        Dim ppslide
    As Object
        On Error Resume Next
        Set ppapp
    GetObject(, "Powerpoint.Application")
        If
    ppapp Is Nothing Then
            Set ppapp
    CreateObject("Powerpoint.Application")
    End If
    On Error GoTo 0
        Set pppres
    ppapp.presentations.Add
        Set ppslide
    pppres.Slides.Add(112)
    With ppapp
    .Activate
    .Visible msoTrue
    .ActiveWindow.viewtype 1
        End With
        ChtObj
    .Copy
        ppapp
    .ActiveWindow.View.Paste
    End With
    End Sub
    i have tried :
    PHP Code:
    ppslide.Shapes.PasteSpecial(110, , , , 0'11 = ppPasteShape
    OR
    PHP Code:
    ppslide.Shapes.PasteSpecial 100, , , , '10 = ppPasteOLEObject
    OR
    PHP Code:
    ppapp.ActiveWindow.View.PasteSpecial 100, , , ,
    but it did not help!
    May 2012
    is there anyone who can help me with my issue?
    Try
    In a standard module
    Public wbkNew               As Workbook
    Public WbkName              As String
    Sub GetChartData(ByRef Chart_Object As ChartObject)
        Dim chtChart            As Chart
        Dim pntPoint            As Point
        Dim lngLoop             As Long
        Dim lngLoopSrs          As Long
        Dim lngSrsCount         As Long
        Dim lngPlotBy           As Long
        Dim lngChartType        As Long
        Dim lngSU               As Long
        Dim lngSecSrsCnt        As Long
        Dim wbkActive           As Workbook
        Dim wksNew              As Worksheet
        Dim varArrYVals()       As String
        Dim strNumFormatHeader  As String
        Dim strNumFormatData    As String
        Dim strNumFormatDataSec As String
        Dim strFmla             As String
        Dim strShtName          As String
        Dim strRange            As String
        Dim strListSep          As String
        Dim strAcell            As String
        Dim blnHasLabel         As Boolean
        Dim blnFlag             As Boolean
        Dim blnSizeStored       As Boolean
        Dim lngArrSecSrs()      As Long
        Dim varArrOutput()      As Variant
        Dim varXVal             As Variant
        Dim varYVal             As Variant
        Dim varVal              As Variant
        Dim varSpltFmla         As Variant
        Dim varSpltRange        As Variant
        With Application
            lngSU = .ScreenUpdating
            .ScreenUpdating = False
            .EnableEvents = False
        Set wbkActive = ThisWorkbook
        strAcell = ActiveCell.Address
        Set chtChart = Chart_Object.Chart
        lngPlotBy = chtChart.PlotBy
        lngSrsCount = chtChart.SeriesCollection.Count
        lngChartType = CLng(chtChart.ChartType)
        Select Case lngChartType
            Case -4111, 51, 52, 57, 58, 65, 93, 94  'Line,Column,Bar
                ReDim varArrOutput(1 To lngSrsCount + 1)
                ReDim varArrYVals(1 To lngSrsCount + 1)
                varXVal = chtChart.SeriesCollection(1).XValues
                varArrOutput(1) = varXVal
                varArrYVals(1) = vbNullString
                varYVal = chtChart.Axes(1, 1).CategoryNames
                strNumFormatHeader = chtChart.Axes(1, xlPrimary).TickLabels.NumberFormat
                If strNumFormatHeader = vbNullString Then strNumFormatHeader = "@"
                strNumFormatData = chtChart.Axes(2, xlPrimary).TickLabels.NumberFormat
                strNumFormatDataSec = chtChart.Axes(2, xlSecondary).TickLabels.NumberFormat
                If strNumFormatDataSec = vbNullString Then blnFlag = True
                For lngLoopSrs = 1 To lngSrsCount
                    varVal = chtChart.SeriesCollection(lngLoopSrs).Values
                    If Not blnFlag Then
                        If chtChart.SeriesCollection(lngLoopSrs).AxisGroup = 2 Then
                            lngSecSrsCnt = lngSecSrsCnt + 1
                            ReDim Preserve lngArrSecSrs(1 To lngSecSrsCnt)
                            lngArrSecSrs(lngSecSrsCnt) = lngLoopSrs
                    varArrOutput(lngLoopSrs + 1) = varVal
                    varArrYVals(lngLoopSrs + 1) = chtChart.SeriesCollection(lngLoopSrs).Name
            Case -4102, 5, 69, 70 'Pie
                Set pntPoint = chtChart.SeriesCollection(1).Points(1)
                blnHasLabel = pntPoint.HasDataLabel
                If Not blnHasLabel Then
                    pntPoint.HasDataLabel = True
                strNumFormatData = pntPoint.DataLabel.NumberFormat
                pntPoint.HasDataLabel = blnHasLabel
                varArrYVals(2) = chtChart.SeriesCollection(1).Name
                varVal = chtChart.SeriesCollection(1).Values
                varArrOutput(2) = varVal
            Case 87 'Bubble
                strListSep = Application.International(5)
                ReDim varArrOutput(1 To lngSrsCount, 1 To 4)
                strShtName = Replace(chtChart.Parent.Parent.Name, "'", "''")
                Application.Goto wbkActive.Worksheets(CStr(strShtName)).Range(CStr(strAcell))
                    strFmla = chtChart.SeriesCollection(lngLoopSrs).Formula
                    strFmla = Mid$(strFmla, InStr(1, strFmla, "(") + 1)
                    strFmla = Replace(Replace(Replace(strFmla, strShtName, ""), "!", ""), ")", "")
                    varSpltFmla = Split(strFmla, strListSep)
                    strRange = vbNullString
                    For lngLoop = 0 To UBound(varSpltFmla)
                        If varSpltFmla(lngLoop) Like "$*$#*" Or varSpltFmla(lngLoop) Like "$*$#*:$*$#*" Then
                            strRange = strRange & strListSep & varSpltFmla(lngLoop)
                        ElseIf varSpltFmla(lngLoop) Like "{#*}" Then
                            varArrOutput(lngLoopSrs, 4) = CSng(Replace(Replace(varSpltFmla(lngLoop), "{", ""), "}", ""))
                            blnSizeStored = True
                    If Len(strRange) > Len(strListSep) Then
                        strRange = Mid$(strRange, Len(strListSep) + 1)
                        varSpltRange = Split(strRange, strListSep)
                        varArrOutput(lngLoopSrs, 1) = Evaluate("'" & strShtName & "'!" & varSpltRange(0))
                        varArrOutput(lngLoopSrs, 2) = Evaluate("'" & strShtName & "'!" & varSpltRange(1))
                        varArrOutput(lngLoopSrs, 3) = Evaluate("'" & strShtName & "'!" & varSpltRange(2))
                        If Not blnSizeStored Then
                            varArrOutput(lngLoopSrs, 4) = Evaluate("'" & strShtName & "'!" & varSpltRange(3))
                    blnSizeStored = False
            Case Else
                GoTo Xit
        Set wbkNew = Workbooks.Add(-4167)
        Set wksNew = wbkNew.Worksheets(1)
        If lngPlotBy = 1 Then
            For lngLoop = 1 To UBound(varArrOutput)
                wksNew.Cells(lngLoop, 1) = varArrYVals(lngLoop)
                wksNew.Cells(lngLoop, 2).Resize(, UBound(varArrOutput(lngLoop), 1)) = varArrOutput(lngLoop)
            wksNew.Cells(2, 2).Resize(UBound(varArrOutput), UBound(varArrOutput(1), 1)).NumberFormat = strNumFormatData
            wksNew.Cells(1, 2).Resize(, UBound(varYVal)).NumberFormat = "@"
            wksNew.Cells(1, 2).Resize(, UBound(varYVal)) = varYVal
            If Err.Number <> 0 Then
                wksNew.Cells(1, 2).Resize(, UBound(varArrOutput(1), 1)).NumberFormat = "@"
                wksNew.Cells(1, 2).Resize(, UBound(varArrOutput(1), 1)) = varYVal
                Err.Clear
            If Not blnFlag Then
                For lngLoop = 1 To lngSecSrsCnt
                    wksNew.Cells(1 + lngArrSecSrs(lngLoop), 2).Resize(, UBound(varArrOutput(lngLoop), 1)).NumberFormat = strNumFormatDataSec
        ElseIf lngPlotBy = 0 Then
                Case 87
                    With wksNew.Range("a2")
                        .Resize(UBound(varArrOutput, 1), UBound(varArrOutput, 2)) = varArrOutput
                        .Offset(, 1).Resize(UBound(varArrOutput, 1), UBound(varArrOutput, 2) - 1).NumberFormat = strNumFormatData
                Case Else
                    GoTo 2
        ElseIf lngPlotBy = 2 Then
    2:
                wksNew.Cells(1, lngLoop) = varArrYVals(lngLoop)
                wksNew.Cells(2, lngLoop).Resize(UBound(varArrOutput(lngLoop), 1)) = Application.Transpose(varArrOutput(lngLoop))
            Err.Clear
            wksNew.Cells(2, 1).Resize(UBound(varYVal)).NumberFormat = "@"
                wksNew.Cells(2, 1).Resize(UBound(varArrOutput(1), 1)).NumberFormat = "@"
                Err.Clear
            wksNew.Cells(2, 1).Resize(UBound(varYVal)) = Application.Transpose(varYVal)
            wksNew.Cells(2, 2).Resize(UBound(varArrOutput(1), 1), UBound(varArrOutput)).NumberFormat = strNumFormatData
            If Not blnFlag Then
                    wksNew.Cells(2, 1 + lngArrSecSrs(lngLoop)).Resize(UBound(varArrOutput(1), 1), UBound(varArrOutput)).NumberFormat = strNumFormatDataSec
        wksNew.UsedRange.Columns.AutoFit
    Xit:
        If Err.Number <> 0 Then Err.Clear: On Error GoTo 0
        With Application
            .ScreenUpdating = lngSU
            .ScreenUpdating = True
    Insert another module and paste the following
    Public Enum PasteFormat
        xl_Link = 0
        xl_HTML = 1
        xl_Bitmap = 2
        xl_Embed = 3
    End Enum
    Sub Copy_Paste_to_PowerPoint(ByRef ppApp As Object, ByRef ppSlide As Object, ByVal ObjectSheet As Worksheet, _
                                        ByRef PasteObject As Object, Optional ByVal Paste_Type As PasteFormat)
        '   Modified version of code originally posted here:
        '       http://www.vbaexpress.com/kb/getarticle.php?kb_id=370
        '   Modified by     : Admin @ ExcelFox.com
        '   Used Late binding so that no issues when users have multiple Excel version
        Dim PasteRange      As Boolean
        Dim objChart        As ChartObject
        Dim lngSU           As Long
        Dim strFName        As String
        Select Case TypeName(PasteObject)
            Case "Range"
                If Not TypeName(Selection) = "Range" Then Application.Goto PasteObject.Cells(1)
                PasteRange = True
            Case "Chart": Set objChart = PasteObject.Parent
            Case "ChartObject": Set objChart = PasteObject
            Case Else
                MsgBox PasteObject.Name & " is not a valid object to paste. Macro will exit", vbCritical
        With Application
            .ScreenUpdating = 0
        ppApp.ActiveWindow.View.GotoSlide ppSlide.slidenumber
        On Error GoTo -1: On Error GoTo 0
        DoEvents
        If PasteRange Then
            If Paste_Type = xl_Bitmap Then
                '//Paste Range as Picture
                PasteObject.CopyPicture Appearance:=1, Format:=-4147
                ppSlide.Shapes.Paste.Select
            ElseIf Paste_Type = xl_HTML Then
                '//Paste Range as HTML
                PasteObject.Copy
                ppSlide.Shapes.PasteSpecial(8, link:=1).Select  'ppPasteHTML
            ElseIf Paste_Type = xl_Link Then
                '//Paste Range as Linked
                PasteObject.Copy
                ppSlide.Shapes.PasteSpecial(0, link:=1).Select   'ppPasteDefault
                '//Copy & Paste Chart Linked
                objChart.Chart.ChartArea.Copy
                ppSlide.Shapes.PasteSpecial(link:=True).Select
            ElseIf Paste_Type = xl_Embed Then
                ppSlide.Shapes.AddOLEObject Left:=100, Top:=50, _
                        Width:=objChart.Width, Height:=objChart.Height, _
                        Filename:=WbkName
                ppSlide.Shapes(1).Select
                Kill WbkName
                '//Copy & Paste Chart Not Linked
                objChart.Chart.CopyPicture Appearance:=1, Size:=1, Format:=2
        '//Center pasted object in the slide
        ppApp.ActiveWindow.Selection.ShapeRange.Align msoAlignCenters, True
        ppApp.ActiveWindow.Selection.ShapeRange.Align msoAlignMiddles, True
    Xit:
        With Application
            .CutCopyMode = False
        AppActivate ("Microsoft Excel")
    and call the procedure like
    Sub kTest()
        Dim ppApp       As Object
        Dim ppSlide     As Object
        Dim blnEmbed    As Boolean
        blnEmbed = True
        Set ppApp = GetObject(, "Powerpoint.Application")
        If ppApp Is Nothing Then
            Set ppApp = CreateObject("Powerpoint.Application")
            ppApp.Visible = True
            ppApp.presentations.Add
        If ppApp.ActivePresentation.Slides.Count = 0 Then
            Set ppSlide = ppApp.ActivePresentation.Slides.Add(1, 12) 'ppLayoutBlank
            ppApp.ActivePresentation.Slides.Add ppApp.ActivePresentation.Slides.Count + 1, 12
            Set ppSlide = ppApp.ActivePresentation.Slides(ppApp.ActivePresentation.Slides.Count)
        Set objChart = ThisWorkbook.Worksheets(1).ChartObjects(1)
        If blnEmbed Then
            Set wbkNew = Nothing
            WbkName = vbNullString
            GetChartData objChart
            If Not wbkNew Is Nothing Then
                wbkNew.Worksheets.Add wbkNew.Worksheets(1)
                objChart.Copy
                wbkNew.Worksheets(1).Paste
                wbkNew.Worksheets(1).ChartObjects(1).Chart.SetSourceData wbkNew.Worksheets(2).Range("a1").CurrentRegion
                wbkNew.SaveAs ThisWorkbook.Path & "\chart_temp.xlsx", 51
                WbkName = wbkNew.FullName
                wbkNew.Close
                Copy_Paste_to_PowerPoint ppApp, ppSlide, objChart.Parent, objChart.Chart, xl_Embed
                GoTo Xit
            Copy_Paste_to_PowerPoint ppApp, ppSlide, objChart.Parent, objChart.Chart, xl_Bitmap
    Xit:
    This will give you a start. Adjust the codes wherever necessary.
    May 2012
    Thanks Admin.
    I see you are creating a temp workbook to embed the chart. However, it does not give the same effect as PasteSpecial - "Use Destination Theme & Embed Workbook (H)". I am using Excel 2010.
    When i right-click the chartobject, i get 3 options:
    1] Open
    2] Edit
    3] Convert.
    But i do not get 'Edit Data' option, which i would normally get when i PasteSpecial into a new Presentation using option "Use Destination Theme & Embed Workbook (H)".
    When i select 'Edit' option, i get an embedded workbook in the chart itself and not as a standalone excel window.
    Can you try copying the chart and pasting it in a new powerpoint presentation and see the difference? See attached files for example.
    In ppt deck, slide 1 is from your code, slide 2 is manually pastespecial by me using option "Use Destination Theme & Embed Workbook (H)". You will notice the difference. When you right-click the 2nd slide chart, it opens a new workbook in a new window with title showing "Chart in Microsoft Excel". I am unable to replicate this option.
    Hope this is clear.
  1. Copy/Paste Excel Range/Chart into Powerpoint VBA
    Last Post: 03-13-2014, 02:59 PM
  2. Add VBA Reference From Another Application Excel To PowerPoint
    By ds1001 in forum Rajan Verma's Corner
    Last Post: 06-02-2013, 02:43 PM
  3. Replies: 2
    Last Post: 04-14-2013, 08:23 PM
  4. Replies: 1
    Last Post: 05-20-2012, 12:23 PM
  5. Saving Embedded Picture From Excel Workbook Sheet To Folder Hard Drive
    By littleiitin in forum Excel and VBA Tips and Tricks
    Last Post: 10-31-2011, 02:31 PM
