Results 1 to 7 of 7
Thread: VBA to Copy Data From Other Workbooks Suddenly Fails
    Jul 2013
    Question VBA to Copy Data From Other Workbooks Suddenly Fails
    Hello all,
    I found a solution on this site to a problem I was having in excel. A few small changes were needed, but then it worked flawlessly. After several times of running the code, I tried again today, but now it doesn't add any new information. It runs the script, no errors, and then doesn't paste any data. I have no idea why it has randomly stopped working.
    Sub BulkImport()
       Dim InFileNames As Variant
       Dim fCtr As Long
       Dim tempWkbk As Workbook
       Dim consWks As Worksheet
       Set consWks = ThisWorkbook.Sheets(1)
       InFileNames = Application.GetOpenFilename _
       (FileFilter:="Excel Files, *.*", MultiSelect:=True)
       If IsArray(InFileNames) Then
          For fCtr = LBound(InFileNames) To UBound(InFileNames)
            With Workbooks.Open(Filename:=InFileNames(fCtr))
                .Sheets(1).Range("A2:I" & .Sheets(1).Range("A" & .Sheets(1).Rows.Count).End(xlUp).Row).Copy consWks.Range("A" & consWks.Rows.Count).End(xlUp)(2)
                .Close 0
          Next fCtr
          MsgBox "No file selected"
       With Application
          .StatusBar = True
          .ScreenUpdating = True
    Any ideas?
    Thanks,
    Amit
    It's working fine.
    can you add this line after With Workbooks.Open...
    MsgBox "Number of cells that have data: " & Application.WorksheetFunction.CountA(.Sheets(1).Range("A2:I" & .Sheets(1).Range("A" & .Sheets(1).Rows.Count).End(xlUp).Row))
    and let us know what the msgbox returns.
    Jul 2013
    Hello,
    I added the line you provided and the output was "Number of cells that have data: 27326"
    Jul 2013
    Interestingly enough, I copied the module from the personal workbook (all workbooks) to the specific workbook that will be using this exclusively, and it worked again. I'm not sure why though.
    The code looks fine. Can you please attach the workbooks here ?
    It's got to do with the difference between ActiveWorkbook and ThisWorkbook.
    ThisWorkbook always refers to the workbook file wherein the code is running from. If you change ThisWorkbook, to ActiveWorkbook, the code should run from the personal.xlsb file too.
    ThisWorkBook object refers to the workbook that the code is contained in. ActiveWorkBook object refers to the workbook that is currently active.
    Most times, they will refer to the same workbook. But if the workbook running the code is not the active workbook then they will point to different objects.
    Jul 2013
    Thank you very much guys. Your prompt and helpful responses helped immensely. I'm still new to all this and I appreciate all your help.
    I'm not sure how to set this thread as [SOLVED], unless that's not needed.
    - Amit
  1. Replies: 2
    Last Post: 05-28-2013, 05:32 PM
  2. Replies: 3
    Last Post: 05-14-2013, 03:25 PM
  3. Form suddenly disappears
    By tfurnivall in forum Access Help
    Last Post: 12-20-2012, 06:47 PM
  4. Replies: 2
    Last Post: 11-08-2012, 01:15 PM
  5. VBA Code to Open Workbook and copy data
    Last Post: 08-15-2012, 06:58 PM
