Results 1 to 10 of 14
Thread: IF Condition To Check Whether Absolute Value Is Greater Than Other Absolute Values
    Jul 2013
    I'm very new to writing codes and i'm trying to incorporate a Code in my macro
    The logic goes like this - Absolute value of Column N should not be greater than the absolute amount in column M or Column R.
    If the amount is greater, then i need a comment in a column stating "ERROR". If it is equal to or less than, then i need a comment stating "OK"
    I have attached my excel data with the macro that I have created.
    The code that is required is one of the last codes that I require to complete my macro.
    Appreciate your assistance.
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40455&p=313035#p313035
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312889#p312889
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312886#p312886
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312752#p312752
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312734#p312734
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312727#p312727
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312724#p312724
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40374&p=312535#p312535
    https://www.eileenslounge.com/viewtopic.php?p=312533#p312533
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40373&p=312499#p312499
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg. 9zYoeePv8sZ9zYqog9KZ5B
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=Ugy_RiNN_kAqUvZ8W994AaABAg. 9xhyRrsUUOM9zYlZPKdOpm
    You don't need a greater than or lesser than conditional VBA. You can just build a formula using VBA instead, and use it in column W (or the last empty column)
    Sub GetErrorOK()
        With Worksheets("ccm_dispute_results")
            .Range("W2:W" & .Cells(.Rows.Count, 1).End(xlUp).Row).Formula = "=IF(OR(ABS(N2)>ABS(R2),ABS(N2)>ABS(M2)),""Error"",""OK"")"
    Anyway, since your query was Excel related, moving this thread to the Excel Help section. Also, please try to give a more meaningful and concise thread title, so that other people looking for similar solutions will be able to get search results from search engines. This can only happen if the thread title used is apt.
    Jul 2013
    Hi, thanks for the code and renaming the Thread title appropriately.
    But why would it throw an error for rows 33,36,37,39 where the numbers match for column N and Column M?
    Jul 2013
    I guess it is due to column R being blank. But there will be many times where my column R will be blank. i.e. Zero amount.
    What would you want to do in that case?
    Jul 2013
    I would still want the same result but keeping in mind that R column would be blank at some ocassions. Would that be possible?
    But a zero value N column is possible. I think my formula above should work.
    EDIT: I posted the above without knowing OP had responded.
    The queries regarding pivot table an mailing is digressing from the original question. So please start a new thread for that.
    OK, so if R is empty (actually, your sheet is showing zeroes, not blanks), then you want the formula to ignore that condition, right? And what about column M? What if that is also empty?
    Jul 2013
    But i can sometimes have column N Blank (Zeroes).
    Jul 2013
    Just want to summarize.
    N column which is the amount should not be greater than any of the columns (M or R) irrespective of the signs (-ve or +ve) or Zeroes/Blanks in the columns.
  1. Absolute Calender Program!
    By Preeti Verma in forum Excel Help
    Last Post: 11-06-2012, 01:19 PM
  2. Macro to check values based on certain text
    Last Post: 11-05-2012, 09:03 PM
  3. Formula Based On Condition
    By Aryan063007 in forum Excel Help
    Last Post: 10-09-2012, 10:37 AM
  4. Loop and Check For Values In Entire Column in Excel
    By Jeff5019 in forum Excel Help
    Last Post: 05-01-2012, 10:34 PM
  5. Calculation with different condition in a cell
    Last Post: 04-04-2012, 08:38 AM
