Results 1 to 5 of 5
Thread: How To Bring Userform In Front Of Another Application Other Than Parent Application
    Jun 2013
    I have created a modeless UserForm in Powerpoint 2013 vba in Windows 8 which displays while the user to perform a certain task in Excel and then press OK.
    When the user switches the program to Excel, the form is hidden behind. I want it to be displayed in front of all opened windows regardless of program type.
    I tried SetWindowsPos but this does not seem to work on Windows 8.
    Is there a way to display the form on top without going through the task of signing up trusted certificate?
    Does the SetWindowsPos give you the desired feature in Win 7 or previous? Don't have a Win 8, so cannot check.
    Jun 2013
    I found the cause
    Thanks to your remark, I tested further and found the cause. It was not the SetWindowPos, but because I wrongly declared the FindWindow API. Now, it's working fine on Powerpoint 2013-Windows 8.
    But curiously, when I bring this VBA to Powerpoint 2010-Windows 7, I obtain an error message saying the program could not read dll. I'll have to find a way so that it works on both PPT 2010 and 2013 on Windows 7 and 8.
    Thank you again.
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6BSa173Z
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6-64Xpgl
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ms39yjd
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ZXJwRCM
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4Pr15NUt
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4I83JelY
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HABa3tnAjhZU
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HABa3KswxL3c
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=UgyBXFxnVWT3pqtdqPx4AaABAg
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=Ugi53h84LUm5bHgCoAEC.7-H0Z7-COoGABZFQ8vjEvY
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABZ8N9O-O8p
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgxREWxgx2z2Lza_0st4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgyikSWvlxbWS24NBeR4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgwNiH4hhyrd2UjDK8d4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HAAf952WoUti
    https://www.youtube.com/watch?v=hz4vb48wzMM&lc=Ugy2N3gvXBNrvWpojqR4AaABAg
    Can you post a trimmed down version of the powerpoint file with the form and vba which works in Win 8. If as you say it's working fine on Win 8, will try to integrate some code to make it compatible for both Win 8 and Win 7.
    Jun 2013
    Thank you for your helpful suggestions. I have since tested with other PCs and found that this problem occurs only on one particular PC. So it must be some error on the side of the PC, not the code itself.
    For reference, here is the script I have written. (This is only the essence. Error handling, etc. are omitted)
    Assuming a UserForm1 is created:
    Public Declare PtrSafe Function SetWindowPos Lib "User32" (ByVal hWnd As Long, ByVal hWndInsertAfter As Long, _
    ByVal X As Long, ByVal Y As Long, ByVal cx As Long, ByVal cy As Long, ByVal wFlags As Long) As Long
    Public Const HWND_TOPMOST = -1
    Public Const HWND_NOTOPMOST = -2
    Public Const SWP_NOMOVE = &H2
    Public Const SWP_NOSIZE = &H1
    Public Declare PtrSafe Function FindWindow Lib "User32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
    Sub ShowFormOnTop()
    Dim bwind As Long
    Load UserForm1
    UserForm1.Show vbModeless
    If UserForm1.Visible = True Then
    bwind = FindWindow(vbNullString, UserForm1.Caption)
    bwind = 0
    SetWindowPos bwind, HWND_TOPMOST, 0, 0, 0, 0, SWP_NOMOVE Or SWP_NOSIZE
    Thank you again.
  1. Replies: 4
    Last Post: 07-02-2013, 03:43 PM
  2. Add VBA Reference From Another Application Excel To PowerPoint
    By ds1001 in forum Rajan Verma's Corner
    Last Post: 06-02-2013, 02:43 PM
  3. Application.Caller
    By Transformer in forum Familiar with Commands and Formulas
    Last Post: 05-01-2013, 12:32 PM
  4. Excel Application.OnKey With Parameter
    By Excel Fox in forum Excel Help
    Last Post: 11-29-2011, 01:31 PM
  5. Application.ScreenUpdating = False not working
    Last Post: 11-08-2011, 08:55 AM
