Thread: VBA Code To Protect Sheet With Only A Few Cells Unlocked
    Dec 2012
    HI
    Workbook has 2 sheets - I need a VBA Code to lock all the cells in a Sheet called "Groups" except for cell range C21:L21 & C32:M36 and also sheet called "Teams" to lock all the cells except C4
    I will assign to a activeX button so could the code please have a password box attached
    Cheers
    Rich
    Try this
    Sub LockCells()
        Const strPWD As String = "Password"
        If strPWD = InputBox("Enter password to protect", "Protect sheets") Then
            With Worksheets("Group")
                .Unprotect strPWD
                .Cells.Locked = True
                .Range("C21:L21,C32:M36").Locked = False
                .Protect strPWD
            With Worksheets("Team")
                .Unprotect strPWD
                .Range("C4").Locked = False
                .Protect strPWD
    Dec 2012
    Where do I place the code...new module....if I want to chande the password where do I do this please
    Cheers
    Rich
    Dec 2012
    No luck with getting this to work...where do I place the code please....where do I set the password
    Rich
  1. Highlighting All the Cells of Active sheet which contains a particular String:
    By littleiitin in forum Excel and VBA Tips and Tricks
    Last Post: 10-18-2013, 04:19 PM
  2. Replies: 14
    Last Post: 06-24-2013, 06:17 PM
  3. Replies: 1
    Last Post: 06-12-2013, 07:42 PM
  4. Replies: 13
  5. Adding charts via code to a protected sheet
    Last Post: 11-14-2012, 05:11 PM
