Results 1 to 10 of 10
Thread: Send Mail Using Lotus Notes With Active Sheet As Attachment Using Lotus Notes
    May 2013
    Dear All,
    I hope you are all doing well,
    Kindly help me and provide me the code that will send the activesheet to someone email located in the same activesheet in the cell E9.
    Please find the attached file wich inclue more details.
    Your kind efforts appreciated in advance.
    MSabra
    Instead of sending it as an attachment, are you fine with sending it as a part of the email body? The format and all will look exactly the same.
    May 2013
    Dear Administrator,
    Thank you for your kind reply.
    Yes please, I want it to be as apart of the email body.
    Thank you
    Moderator
    Jul 2012
    Sub Mail_Active_Sheet()
        'path, name and extension for tempfile - change to suit
        c00 = "G:\My documents\TempFile." & CreateObject("scripting.filesystemobject").getextensionname(ThisWorkbook.Name)
        c01 = ThisWorkbook.FileFormat
        'Copy active sheet
        ThisWorkbook.ActiveSheet.Copy
        'Save attachment
        With ActiveWorkbook
            .SaveAs c00, c01
            .Close False
        'Create mail
        With CreateObject("Outlook.Application").createitem(0)
            .to = ActiveSheet.Range("E9")
            .Subject = ActiveSheet.Range("B2")
            .attachments.Add c00
            .display '.Send
        'Delete tempfile
        Kill c00
        Application.DisplayAlerts = True
    May 2013
    Thank you very much Bakerman!
    Kindly be informed that I don't have Outlook application in my Computer! we are using another application called "Lotus Notes" if yo know it.
    In this case how shall I modify the code to suit our mail application.
    Thank you in advance
    Untested...
    Sub SendLotusMail()
        Dim noSession As Object, noDatabase As Object, noDocument As Object
        Dim obAttachment As Object, EmbedObject As Object
        Dim c00 As String, c01
        'Copy active sheet
        'Save attachment
        With ActiveWorkbook
            .SaveAs c00, c01
            .Close False
        'Instantiate the Lotus Notes COM's  Objects.
        Set noSession = CreateObject("Notes.NotesSession")
        Set noDatabase = noSession.GETDATABASE("", "")
         'If Lotus Notes is not open then open the mail-part of it.
        If noDatabase.IsOpen = False Then noDatabase.OPENMAIL
         'Create the e-mail and the attachment.
        Set noDocument = noDatabase.CreateDocument
        Set obAttachment = noDocument.CreateRichTextItem("stAttachment")
        Set EmbedObject = obAttachment.EmbedObject(1454, "", c00)
         'Add values to the created e-mail main properties.
        With noDocument
            .Form = "Memo"
            .SendTo = ActiveSheet.Range("E9").Value
            .Subject = ActiveSheet.Range("B2").Value
            .Body = "Message Here"
            .SaveMessageOnSend = True
         'Send the e-mail.
        With noDocument
            .PostedDate = Now()
            .Send 0, ActiveSheet.Range("E9").Value
        Kill c00'Delete the temporary file
    ErrorMsg:
        If Err.Number = 7225 Then
            MsgBox "The file cannot be found in the location ", vbOKOnly, "Error"
        ElseIf Err.Number = 5 Then
            MsgBox "Please ensure that you are logged in to Lotus Notes", vbExclamation, "Lotus Notes"
        ElseIf Err.Number = 8965 Then
            MsgBox "User is not logged in or user ID file is in use elsewhere and cannot be modified."
            MsgBox Err.Number & Err.Description
    Last edited by Excel Fox; 07-01-2013 at 01:07 PM. Reason: bakerman's suggestion of killing included
    Moderator
    Jul 2012
    @ Sam
    The attachment could also be removed afterwords by using Kill (if necessary)
    Don't forget to release the objects from memory.
    Right. Acknowledged that bakerman :D
    May 2013
    Thank you Administrator for your kind efforts.
    I still have a problem with the file name or path! please have a look to the picture hereunder:
    for mor details about the problem I faced :
    Sub SendLotusMail()
        c00 = "D:\TempFile." & CreateObject("scripting.filesystemobject").getextensionname(ThisWorkbook.Name)
        'Copy active sheet
        'Save attachment
        With ActiveWorkbook
            .SaveAs c00, c01   ‘ Here is the problem I faced
    .Close False
        Set noDatabase = noSession.GetDatabase("", "")
        With noDocument
            .Form = "Memo"
         'Send the e-mail.
        With noDocument
            .PostedDate = Now()
        Kill c00 'Delete the temporary file
    ErrorMsg:
    Please have a look to the attached file:
    Payroll-1.xlsm
    Moderator
    Jul 2012
    Was the workbook you ran the code from already saved on HD or was it a new one ?
    Because for me it works fine. Try this one
    Sub tst()
    MsgBox c00 & "," & c01
    In the messagebox you should see D:\Tempfile. then extension (xls,xlsm) then number (56,52)
  1. Replies: 2
    Last Post: 07-02-2013, 02:36 PM
  2. Replies: 6
    Last Post: 06-05-2013, 11:33 PM
  3. Replies: 4
    Last Post: 03-01-2013, 10:48 PM
  4. Outlook Send Mail With Multiple Recipient and CC
    By noobtron in forum Excel Help
    Last Post: 10-31-2012, 07:14 PM
  5. Send Lotus Notes Email Using VBA
    Last Post: 09-08-2011, 09:00 AM
