Results 1 to 8 of 8
Thread: Toggle Chart Data Using Option Buttons And Formula
    Dec 2012
    The sample file attached shows data and a graph. With option buttons can the graph area be toggled so that it displays all the data bars (D17:R22) or it shows just the average of all the data bars (D23:R23).The option between 2 graphs....
    Not sure if this is possible
    Regards
    Rich
    There could be numerous ways to do this. It all depends on how you approach it. One way would be to make use of NA() to hide series points from a chart.
    By the way, this one also has a very nice method that you could make use of
    Interactive Charts with Checkboxes and Formulas | Peltier Tech Blog | Excel Charts
    Dec 2012
    Hi Excel Fox
    Yours is a great example and i adopted that techniques
    I followed your set up with the NA and formula and linked the Cell to the Stats Button.When i now toggle between the 2 the Graphs do not change.There is something i have missed here.I see that the Average button is not linked to the cell...is this correct
    Thank you
    Rich
    Dec 2012
    My chart does not alternate between the 2 graphs...what am i not doing please?
    Rich
    rich, the new table you have below should be the source for the chart. You haven't changed that chart source yet. Once you do that, it should work fine.
    Dec 2012
    Hi Excel Fox
    Thanks again for your help
    Rich
    Dec 2012
    Hi Excel Fox
    I now haveit working..thank you
    When I have the daily graph visible the bar lines are in there respected areas but when I select the average button the bars are not in alignment........they are thin bars..I tried but is there a way to have the bars line up in there area and also have the bars thick (wide)
    Rich
  1. How To Use Option Buttons To Switch Between Sheets
    By raybugge in forum Excel Help
    Last Post: 06-29-2013, 03:20 PM
  2. Minimize and Maximize option in Excel UserForm
    By shabbirtaibany in forum Excel Help
    Last Post: 09-23-2012, 07:05 PM
  3. Replies: 3
    Last Post: 05-14-2012, 11:30 AM
  4. 2007 PPT Chart Data is not Reflecting In Chart
    By littleiitin in forum Powerpoint Help
    Last Post: 04-28-2012, 01:42 PM
  5. Get Chart's Source Data VBA
    Last Post: 11-24-2011, 07:54 AM
