Results 1 to 10 of 13
Thread: Move Data Only After All Required Range Cells Have Been Filled
rich_cirillo Move Data Only After All... 06-26-2013, 07:00 AM
Excel Fox hi rich_cirillo Thread... 06-26-2013, 07:51 AM
rich_cirillo Hi excel Fox My... 06-26-2013, 08:03 AM
rich_cirillo Hi Still need help with... 06-28-2013, 04:39 AM
Admin Hi try this. Option... 06-28-2013, 07:50 AM
rich_cirillo Thanks Admin I keep... 06-28-2013, 03:12 PM
Admin Hi Adjust your ranges. The... 06-28-2013, 10:44 PM
rich_cirillo Hi Admin Thanks Are you... 06-29-2013, 02:45 AM
Admin Hi Yes, I'm talking about... 06-29-2013, 03:53 PM
rich_cirillo Hi Admin Thank you 06-29-2013, 05:05 PM
rich_cirillo Hi How can i make this... 07-26-2013, 06:16 AM
Admin Hi Add this code in... 07-26-2013, 07:32 AM
rich_cirillo Thanks Admin....works great 07-26-2013, 07:39 AM
    Dec 2012
    Hi Admin
    Can we finish this with a final alteration to the Clear Data code...can the Clear Data button only be functional once the data for that week has been entered into Records sheet...once the data has been Transferred to the Record Sheet by pressing the Transfer Data To Records button then the Data can be cleared
    Rich
    hi rich_cirillo
    Thread titles should give a clear and concise objective of the thread. Please do not use words like 'Help', 'Please', etc. Users searching for objectives similar to your request will not be able to search threads with relevant keywords. You have been using online communities for quite some time now, and are expected to adhere to the general guidelines.
    Thanks for co-operating. Please edit the thread, and give an appropriate thread title.
    EF
    Dec 2012
    Hi excel Fox
    My apologies...I tried to edit my post but was unable to do for some reason
    Rich
    Dec 2012
    Still need help with this request if possible
    Rich
    try this.
    Dim nmFlag  As Name
    Sub insert_data()
        Dim d, i As Long, k, q, x, r As Long, Rng1 As Range
        Dim c As Long, lRow As Long, Rng2 As Range, Hdr
        lRow = Sheets("records").Range("c" & Sheets("records").Rows.Count).End(3).Row
        Set Rng2 = Sheets("records").Range("c3:m" & lRow)
        d = Rng2.Value2
        q = Application.Index(d, 0, 1)
        Set Rng1 = Sheets("data").Range("b32:L37")
        Hdr = Sheets("data").Range("c21:l21")
        If Application.WorksheetFunction.CountA(Rng1) = Rng1.Cells.Count Then
            k = Rng1.Value2
            x = Application.Match(k(1, 1), q, 0)
            If Not IsError(x) Then
                If Len(d(x, 2)) * Len(d(x, 3)) Then 'check 2 columns whether they have data in those cells
                    MsgBox "It seems data already been entered for date " & CDate(k(1, 1))
                    For r = 1 To UBound(k, 1)
                        For c = 1 To UBound(k, 2)
                            d(r + x - 1, c) = k(r, c)
                    For c = 2 To UBound(d, 2): d(x - 1, c) = Hdr(1, c - 1): Next
                Set Rng2 = Sheets("records").Range("c3:m" & lRow + 9)
                d = Rng2.Value2
                        d(UBound(d, 1) - UBound(k, 1) + r, c) = k(r, c)
                For c = 2 To UBound(d, 2): d(UBound(d, 1) - UBound(k, 1), c) = Hdr(1, c - 1): Next
            Rng2 = d
            Rng2.Columns(1).NumberFormat = "m/d/yyyy"
            With Rng2.Resize(Rng2.Rows.Count + 2, Rng2.Columns.Count)
                .BorderAround , xlThin
                .Borders(xlInsideHorizontal).Weight = xlThin
                .Borders(xlInsideVertical).Weight = xlThin
                .Rows.RowHeight = 25
            Set nmFlag = ThisWorkbook.Names("Flag")
            If nmFlag Is Nothing Then
                ThisWorkbook.Names.Add "Flag", "TRUE", 1
                nmFlag.RefersTo = "TRUE"
            MsgBox "Cannot transfer until all data entered", vbCritical
    Sub ClearData()
        Dim Rng     As Range
        Set Rng = Sheets("data").Range("c32:l37")
        If Application.WorksheetFunction.CountA(Rng) = Rng.Cells.Count Then
            If Evaluate("Flag") Then
                Sheets("data").Range("c32:l37").ClearContents
                    ThisWorkbook.Names.Add "Flag", "FALSE", 1
                    nmFlag.RefersTo = "FALSE"
                MsgBox "Transfer the Data first", vbInformation
            MsgBox "Cannot be deleted as incomplete", vbCritical
    Dec 2012
    Thanks Admin
    I keep getting 2 errors - 1 for insert data and the other 1 for clear data
    Regards
    Rich
    Adjust your ranges. The number of columns for both the source as well as destination range should be same. The header columns will be one columns less than the source range.
    Dec 2012
    Hi Admin
    Are you referring to the ranges within the code?
    I am not sure i follow where to change.I would like to learn about code
    Rich
    Yes, I'm talking about within the code.
    Set Rng2 = Sheets("records").Range("c3:n" & lRow)
    Set Rng1 = Sheets("data").Range("B32:m37")
        Hdr = Sheets("data").Range("C21:m21")
    Dec 2012
    Hi Admin
    Thank you
  1. Replies: 4
    Last Post: 07-02-2013, 11:32 AM
    Last Post: 06-24-2013, 07:40 PM
  3. Replies: 13
  4. Replies: 22
    Last Post: 03-19-2013, 07:57 AM
  5. Get last Filled Cell address in a Range.
    Last Post: 03-24-2012, 01:08 AM
