thanks theladysaphir for the kind words. I thought it shouldn't have even had that sheet missing error, cause I coded to check if the sheet exits, and if it doesn't then add a new sheet. I tend to make users do as less manual work as possible. So adding a sheet was one of the manual steps to eliminate. Are you sure the runtime error was because of the sheet / sheet name not being found?
