Hello,
I am putting together a looping code that that will go down a list of emails in Excel and compose an email automatically, pulling a set of information from another set of cells per user on a monthly basis (the data in these cells will change).
The code I found to utilize will only let me pull in from one column to maintain the loop, but I need to pull in from multiple columns to compose the email.
VB:
Sub Preview()
    I = Cells(2, "B").Value ' dynamising startrownumber to user fed value at cell B2
    Do ' start the action ,buddy!!!!
        Subj = Cells(I, "A").Value
        Filepath = Cells(I, "B").Value
        EmailTo = Cells(I, "C").Value
        CCto = Cells(I, "D").Value
        msg = Cells(I, "E").Value 'I THINK THIS IS WHERE AM HAVING TROUBLE. WILL ONLY PULL FROM COLUMN E.
        Application.DisplayAlerts = False ' hey macro ,i dont wanna make you take time ,so this command to save time to avoid displays
        Dim OutApp As Object
        Dim OutMail As Object
        Set OutApp = CreateObject("Outlook.Application")
        Set OutMail = OutApp.CreateItem(0)
        With OutMail
            .To = EmailTo
            .CC = CCto
            .BCC = ""
            .Subject = Subj
            .body = msg
            .Attachments.Add Filepath
            .display
        On Error Goto 0
        Set OutMail = Nothing
        Set OutApp = Nothing
        Application.DisplayAlerts = True
        I = I + 1
        Cells(1, "A").Value = "Outlook sent Time,Dynamic msg preview  count  =" & I - 3
    Loop Until Cells(I, "C").Value = "0"
Is there a better way to pull this information in? Basically I have the body of the email typed into the one cell in this column, but this does not allow me to pull in the individual set of data each month in a usable format.
Thank you!!!!
-Kevin
