HI everyone,
The records in column D (name) have identical names which can be 4-5,
The Column B (reference) have different numbers in it.
The column A contains ID's. (Which is different)
Now i want to allocate the same ID's (Col A) to all the identical names in Column D.
Before giving ID to identical group I have to make selection from Column B (Reference)
For example identical 5 name in column D, then Column B has 5 different nos. like 1001,1002,2001,2002,2003 then 2001 ID (Column A)
is most important and this ID will be given next 4 ID's Col A.
I have a big data base to convert like this so whats the best option, a proper direction, Confused?
Please help?
https://eileenslounge.com/viewtopic.php?p=244184#p244184
https://eileenslounge.com/viewtopic.php?p=246586#p246586
https://eileenslounge.com/viewtopic.php?p=246112#p246112
https://eileenslounge.com/viewtopic.php?p=245761#p245761
https://eileenslounge.com/viewtopic.php?p=245722#p245722
https://eileenslounge.com/viewtopic.php?p=245616#p245616
https://eileenslounge.com/viewtopic.php?p=247043#p247043
https://www.excelfox.com/forum/showthread.php/2307-VBA-Range-Sort-with-arrays-Alternative-for-simple-use
https://eileenslounge.com/viewtopic.php?p=245238#p245238
https://eileenslounge.com/viewtopic.php?p=245131#p245131
https://eileenslounge.com/viewtopic.php?f=18&t=31638
https://eileenslounge.com/viewtopic.php?p=244579#p244579
https://eileenslounge.com/viewtopic.php?p=244648#p244648
https://eileenslounge.com/viewtopic.php?p=244647#p244647
https://eileenslounge.com/viewtopic.php?p=244577#p244577
https://eileenslounge.com/viewtopic.php?p=245201#p245201
https://eileenslounge.com/viewtopic.php?p=243975#p243975
https://eileenslounge.com/viewtopic.php?p=243884#p243884
https://eileenslounge.com/viewtopic.php?p=242439#p242439
https://eileenslounge.com/viewtopic.php?p=243595#p243595
https://eileenslounge.com/viewtopic.php?p=243589#p243589
https://eileenslounge.com/viewtopic.php?p=243002#p243002
https://www.eileenslounge.com/viewtopic.php?p=242761#p242761
https://eileenslounge.com/viewtopic.php?p=242459#p242459
https://eileenslounge.com/viewtopic.php?p=242054#p242054
https://eileenslounge.com/viewtopic.php?p=241404#p241404
https://eileenslounge.com/viewtopic.php?p=229145#p229145
https://eileenslounge.com/viewtopic.php?p=228710#p228710
https://eileenslounge.com/viewtopic.php?p=226938#p226938
https://eileenslounge.com/viewtopic.php?f=18&t=28885
https://eileenslounge.com/viewtopic.php?p=222689#p222689
https://eileenslounge.com/viewtopic.php?p=221622#p221622
https://eileenslounge.com/viewtopic.php?f=27&t=22512
https://eileenslounge.com/viewtopic.php?f=26&t=26183
https://eileenslounge.com/viewtopic.php?f=26&t=26030
https://eileenslounge.com/viewtopic.php?p=202322#p202322
https://www.excelforum.com/word-formatting-and-general/1174522-finding-a-particular-word-phrase-in-word.html#post4604396
