Results 1 to 7 of 7
Thread: How To Create A Graph In Excel
    Dec 2012
    I am new to graphs.Can a graph have data in Sheet1 and from this a Graph created in Sheet 2 row 2.I would need the letters and dates along the bottom (X) and the score scale up the side (Y).The score would be between 0-100
    Can there be a small gap between each date so as to separate each group of daily data
    Can a graph be created from exactly how I have displayed it in Sheet 1
    Cheers
    Rich
    Apr 2011
    Looks like a visit to YouTube to view some charting tutorials will be of help
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314054#p314054
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313971#p313971
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313909#p313909
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40574&p=313879#p313879
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313859#p313859
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313855#p313855
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313848#p313848
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313843#p313843
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313792#p313792
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313771#p313771
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313767#p313767
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313746#p313746
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313744#p313744
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313741#p313741
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313622#p313622
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313575#p313575
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313573#p313573
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313563#p313563
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313555#p313555
    https://www.eileenslounge.com/viewtopic.php?f=39&t=40265&p=313468#p313468
    https://www.eileenslounge.com/viewtopic.php?f=42&t=40505&p=313411#p313411
    https://www.eileenslounge.com/viewtopic.php?f=32&t=40473&p=313384#p313384
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313382#p313382
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313380#p313380
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313378#p313378
    https://www.eileenslounge.com/viewtopic.php?f=32&t=40473&p=313305#p313305
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40455&p=313035#p313035
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312889#p312889
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312886#p312886
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312752#p312752
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312734#p312734
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312727#p312727
    https://www.eileenslounge.com/viewtopic.php?f=18&t=40411&p=312724#p312724
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40374&p=312535#p312535
    https://www.eileenslounge.com/viewtopic.php?p=312533#p312533
    https://www.eileenslounge.com/viewtopic.php?f=44&t=40373&p=312499#p312499
    I agree. You'll have to rearrange your data to get what you're looking for. Go through the charting tutorials as suggested, and you'll get a better idea of how you achieve your objective.
    Dec 2012
    Will do.Thanks a lot
    A Question: is it possible to have data in sheet 1 and then have only the Graph displayed in sheet 2
    Cheers,
    Rich
    Quote Originally Posted by rich_cirillo View Post
    It is possible.
    Apr 2011
    I find it easier to create the chart on the same sheet as the data you want to plot then moving the chart to the other sheet.
    You may select a chart the use the standard cut and paste actions to move it.
    Dec 2012
    I now plan to have the graph on the same sheet as the data......can this be done with VBA?
    Rich
  1. How To Create DropDown ListBox In Excel
    By lokvan in forum Excel Help
    Last Post: 12-23-2014, 04:43 PM
  2. Excel VBA Code to Add New Sheets
    By cdurfey in forum Excel Help
    Last Post: 06-25-2013, 08:05 AM
  3. Multiple graph in userform
    By Tony in forum Excel Help
    Last Post: 10-20-2012, 09:32 AM
  4. Data sorting & Graph making according filters
    Last Post: 04-05-2012, 08:56 AM
  5. UDF to Create In-Cell Chart in Excel
    Last Post: 08-13-2011, 09:53 AM
