Thread: How To Prevent Adding Duplicated Record In A Table Using VBA
    Apr 2013
    I need to prevent adding duplicated record in a table .. I attach sample file
    I input date on the left.. when I click a button, the range of records are copied and added to the table .. I need to check if the record has been added before adding it .. The duplicated record is a combination of name and date .. the same account should not be entered twice in the same day .. I appreciate your help .. thanks
    Use this function to identify the duplicate.
    Function ISDUPLICATE(ByVal ExeDate As Date, AccountName As String) As Boolean
        Dim k   As Variant, i As Long, d As Long
        AccountName = LCase(AccountName)
        d = CLng(ExeDate)
        With Worksheets("EXEC Plan")
            k = .Range("s6:t" & .Range("s" & .Rows.Count).End(3).row).Value2
            For i = 1 To UBound(k, 1)
                If k(i, 1) = d And LCase(k(i, 2)) = AccountName Then
                    ISDUPLICATE = True
                    Exit Function
    and in your sub use it like
    If ISDUPLICATE(CDate(Range("b6").Value), Range("c6")) Then Exit Sub
    Apr 2013
    Thanks ..
    This worked perfect !! .. I appreciate your help thank you very much !!
  1. Export data from Excel to Access Table (ADO) using VBA
    Last Post: 02-24-2015, 07:53 PM
  2. Excluding Records of one Table from the Other Table
  3. Copy Table Range Till Last Row Using VBA
    By ivandgreat in forum Excel Help
    Last Post: 05-09-2013, 05:41 PM
  4. Vlookup Multiple Values By Adding Formula With Loop In VBA
    Last Post: 04-22-2013, 04:49 PM
  5. Adding Scroll bar to image box in vba
    Last Post: 12-13-2011, 09:47 PM
