Results 1 to 9 of 9
Thread: SUMIFS multiple criteria from same column
    Apr 2011
    I have SUMIFS formula where I want to use multiple criteria from the same column apart from other columns.
    I have attached the sample file.
    Pls assist.
    excel_learner
    (Using XL 2007 & 2010)
    -------Learning never stops!
    1.
    =SUMPRODUCT(SUMIFS($C$2:$C$7,$A$2:$A$7,INDEX(A14:B 14,0,0),$B$2:$B$7,$C$14))
    2.
    =SUM(SUMIFS($C$2:$C$7,$A$2:$A$7,{"Micl","Pirt"},$B $2:$B$7,$C$14))
    3.
    =SUMPRODUCT(--ISNUMBER(MATCH(A2:A7,A14:B14,0)),--(B2:B7=C14),C2:C7)
    HTH
    SUMIFS Multiple Criteria in Single Cloumn
    1.
    2.
    3.
    HTH
    I also faced same problem but above formulas solved my problem. Thanks. But I have query. While using formula no. 2, I tried to give cell reference instead of placing values in double quotation like {"Micl", "Pirt"} but it didn't work. Please can you tell me how SUM function worked in this formula.
    Although formula no. 1 solved my problem and I selected range instead of placing values in curly bracket and double quotations. But I am unable to interpretate how SUMPRODUCT is working here. Please tell me how SUMPRODUCT is working here.
    Apr 2011
    thanks, but i have date also in the criteria in cell C9.
    excel_learner
    OK.
    1.
    =SUMPRODUCT(SUMIFS(INDEX($C$2:$E$7,0,MATCH(C9,C1:E 1,0)),$A$2:$A$7,INDEX(A14:B14,0,0),$B$2:$B$7,$C$14 ))
    2.
    =SUM(SUMIFS(INDEX($C$2:$E$7,0,MATCH(C9,C1:E1,0)),$ A$2:$A$7,{"Micl","Pirt"},$B$2:$B$7,$C$14))
    3.
    =SUMPRODUCT(--ISNUMBER(MATCH(A2:A7,A14:B14,0)),--(B2:B7=C14),INDEX($C$2:$E$7,0,MATCH(C9,C1:E1,0)))
    HTH
    Apr 2011
    Thanks, its working...
    excel_learner
    Glad I could help
    May 2012
    Good Afternoon - I apologize in advance for responding to this thread, but am new and can't figure out where to post my own thread? I have a similar problem but not sure it's the same solution. How do I attach my workbook?
    Thanks in advance.
    Quote Originally Posted by MarkJohn View Post
    ...and can't figure out where to post my own thread? How do I attach my workbook?
    First, click the Forum button located under the EXCELFOX.com logo. Next, locate the "Help Section" forum and click the sub-forum link labeled "Excel Help". This will take you into the Excel Help sub-forum where you can read other threads; however, located towards the top is a large button labeled "+Post New Thread"... click that button to take you to a form that you can type your question into. Located below the message panel where you type your question is another panel titled "Additional Options"... inside its panel is a button labeled "Manage Attachments"... click that button and one of its own options allows you to "Upload Files from your Computer".
  1. Replies: 3
    Last Post: 05-23-2013, 11:17 PM
  2. Replies: 7
    Last Post: 05-15-2013, 02:56 PM
  3. Replies: 7
    Last Post: 05-15-2013, 07:55 AM
  4. Replies: 4
    Last Post: 08-11-2012, 10:50 PM
  5. SUM Value With Multiple Criteria In Same Column
    By MarkJohn in forum Excel Help
    Last Post: 05-18-2012, 07:52 AM
