Results 1 to 6 of 6
Thread: Open And Activate Workbook Before Runing Macro
    Apr 2012
    I have set up the following code to open open workbooks and to activate the macro
    This is just a sample of what I want to set up as I have several branches. The code vworks perfectly. However, when selecting the macro update_workbooks. I would like to first like to select/see the name of the workbook that is going to be updated by this macro so that I can which file to choose from the downloaded files
    Your assistance in resolving this is most appreciated
    HTML Code:
    Sub Open_Workbooks()
        ChDir ("C:\My documents")
        Workbooks.Open Filename:="C:\My Documents\BR1 parts sales.xlsm"
        Workbooks.Open Filename:="C:\My Documents\Br1 service sales.xlsm"
        Windows("Open Parts & Service Sales account.xls").Activate
    HTML Code:
    Sub Update_Workbooks()
            Windows("BR1 parts sales.xlsm").Activate
       Application.Run "'Br1 Parts Sales.xlsm'!Auto"
        ActiveWorkbook.Close
        Windows("Br1 Service sales.xlsm").Activate
        Application.Run "'BR1 service Sales.xlsm'!Auto"
    Try passing the workbook by reference on to the routine that does the work, instead of relying on 'ActiveWorkbook'
    If each workbook contains an 'auto' macro this will suffice (since an 'auto' macro runs automatically when opening the file...)
    Sub M_snb()
        with getobject("C:\My Documents\BR1 parts sales.xlsm")
            .close true
        end with
        with Getobject("C:\My Documents\Br1 service sales.xlsm")
           .close true
        end with
    PS. Avoid 'Select' and 'Activate' in VBA.
    Apr 2012
    Thanks for the reply. I have 30 workbooks that needs to be updated from files that are downloaded. What I would like to see is the workbook name before the update macro is run. i.e have a pause button so that one can see the workbook before the update macro is run for a particular workbook
    You can use the
    ThisWorkbook.UpdateLinks = 3
    property in each workbook. No macro required.
    Apr 2012
    Thanks for the help, much appreciated
  1. Excel VBA Macro To Open A File Through Browse Dialog Box
    Last Post: 04-05-2013, 12:59 PM
  2. VBA Code to Open Workbook and copy data
    Last Post: 08-15-2012, 06:58 PM
  3. Replies: 8
    Last Post: 08-05-2012, 10:07 AM
  4. Get Name List of All Open Workbook Files
    Last Post: 04-07-2012, 12:18 PM
  5. Assign an event to chart on workbook open
    Last Post: 02-20-2012, 07:43 AM
