Thread: hard question
    Mar 2013
    formula
    Dear teachers
    I have a question has puzzled me a lot is:
    In the asphalt there is a general specification for all sizes of gravel, sand and soft materials per sieves For example, one screens in the specification must be material passers proportion of 44-67 and must be design Maaldlh of asphalt mix for this sieve of 58-56 this first
    Secondly: specification, for example, limits of 76-90 and design equation of 80-90 now we have Mnkhlin the and Moasf limits to them and the limits of the equation as well.
    The question is how to put an asterisk (*) if the model Screened outside the boundaries of the equation and how the author (**) if the model Screened outside the specification limits note that the result of the equation and limits specified limits are placed in the same cell I worked Formh in the Excel for the purpose of accounts
    Do not post threads with titles that do not convey an information about the contents of the thread. Thread titles should be clear and concise, and search friendly, allowing people to recognize what the posts would contain, and also act as an identifier for search engines.
    You need to be more clear than that mahmoud. Can you please explain the requirements with a sample workbook, and also show how the expected output should look like.
  1. Question on UDF LookUpConcat
    By K2` in forum Excel Help
    Last Post: 05-07-2013, 10:25 PM
  2. Workbook Event running VBA question
    By jamilm in forum Excel Help
    Last Post: 12-29-2012, 12:12 AM
  3. Question
    By lokvan in forum Excel Help
    Last Post: 12-04-2012, 08:49 AM
  4. Complicate Excel question?
    By Wilhelm Sorban in forum Excel Help
    Last Post: 07-21-2012, 05:07 PM
  5. Saving Embedded Picture From Excel Workbook Sheet To Folder Hard Drive
    By littleiitin in forum Excel and VBA Tips and Tricks
    Last Post: 10-31-2011, 02:31 PM
