Hi All,
I have been trying to resolve the following issue which is driving me crazy! In a nutshell, I am trying to autofilter a date column based on a date range (from, to) which is provided by users from main menu. When I use string varibales to pass these dates to the FilterDate sub, I get wrong results but if I hard code the date range, I get good results. Below are more details....
I have a VBA sub which is use to filter out my data in a seperate worksheet as follows:
Private Sub FilterData(bRemoveExistingFilter As Boolean, _
Sht As Worksheet, _
Rng As Range, _
iField As Integer, _
Optional vCriteria1 As Variant, _
Optional vCriteria2 As Variant)
Sht.Select
With Sht
'Remove any existing filters
If (bRemoveExistingFilter) Then
Rng.AutoFilter
If IsMissing(vCriteria1) Then
Rng.AutoFilter Field:=iField
If (IsMissing(vCriteria2)) Then
Rng.AutoFilter Field:=iField, Criteria1:=vCriteria1, Operator:=xlFilterValues
Rng.AutoFilter Field:=iField, Criteria1:=vCriteria1, Operator:=xlAnd, Criteria2:=vCriteria2
The sub is working. The problem is that if I call this sub using my program variables (sReportingFromDate, and sReportingToDate) as below, the target date column is not filtered correctly and I get wrong results:
Call FilterData(False, oData, oData.Range("A2").CurrentRegion, iDatesFilteringColumn, ">=" & sReportingFromDate, "<=" & sReportingToDate)
The problem seems to be the ">=" & sReportingFromDate, "<=" & sReportingToDate" part of the above call. The sReportingFromDate and sReportingToDate are STRING variables which users pass the date range they need to do reporting.
If I call the sub using hard coded dates like below, I get the correct result:
Call FilterData(False, oData, oData.Range("A2").CurrentRegion, iDatesFilteringColumn, ">=11/1/2013", "<=11/30/2013")
Can you please help me resolve this issue which is preventing me from moving forward with the rest of my program logic? thanks!
