Thread: Calculating Subtotals Within Groups of Data Using UNION
Transformer Calculating Subtotals Within... 05-24-2013, 09:52 AM
Excel Fox The sub-totals appear below... 05-24-2013, 11:54 AM
    Member Transformer's Avatar
    Mar 2012
    Lightbulb Calculating Subtotals Within Groups of Data Using UNION
    UsefulGyaan Has Posted the Following On 05-24-2013 10:04 AM:
    Problem Statement: There is a table named Employee which has department wise employee details as given below. We want to find out gender-wise subtotals and a grand total for each department. Dept Employee_ID Gender IT E123 M IT E124 M IT E125 M IT E126 M IT E127 F IT E128 F HR E129 M HR […]
    The sub-totals appear below each group only because "T...." is larger than "M" or "F". For the sake of the purists, adding an order by would be more apt.
    PHP Code:
    SELECT [CUSTABLE].[Dept], [CUSTABLE].[Gender], [CUSTABLE].[Pop]
    FROM
    (SELECT [Dept], As [Order], [Gender], Count(*)  as Pop
    FROM
    [Employee]  GROUP BY [Dept], [Gender]
    UNION SELECT [Dept], As [Order], "Total"Count(*) as Pop
    FROM
    [Employee]  GROUP BY [Dept]) CUSTABLE
    ORDER BY
    [CUSTABLE].[Dept], [CUSTABLE].[Order];
  1. Calculating Ratio Within Groups using Self Join
    Last Post: 05-21-2013, 07:52 PM
  2. Effective way of calculating the difference
    By zzzqinzzz in forum Excel Help
    Last Post: 12-13-2012, 03:39 PM
  3. VBA Code to extract subtotals
    Last Post: 12-02-2012, 01:15 PM
  4. Email merge unique messages to groups and individuals
    By RagingWahoo in forum Excel Help
    Last Post: 10-14-2012, 11:32 PM
