Thread: Sum Of A Row of Cells In Multiple Columns Based On Criteria And Column Index
    Apr 2011
    I have list of codes (range) and same codes are found in column of a worksheet, I want to lookup code in the range and match with column if found sum all the codes which in the range matching in column.
    I have also attached the example worksheet for easy reference.
    kindly assist.
    excel_learner
    (Using XL 2007 & 2010)
    -------Learning never stops!
    Why do you need to Vlookup at all? You are summing it from the same row anyway, although from different columns. Your requirement isn't clear. But I guess this is what you wanted
    L4=SUMPRODUCT((--ISNUMBER(MATCH(VALUE($C$3:$J$3),D$12:D$17,0)))*(--($C4:$J4))) and copy down and across. if this is not what you wanted, can you clarify?
    Apr 2011
    sorry for that, in fact i have a formula for results but i have to insert vlookup for each code and sum as can be seen in column L, i want it to be simple formula whereby the formula checks the code in range from column given e.g D11 and D12 and match with 1st row and sum the values. I hope it is clear now.
    excel_learner
    Apr 2011
    Thanks, this is what i wanted.
    excel_learner
  1. Replies: 4
    Last Post: 06-01-2013, 01:08 PM
    Last Post: 03-05-2013, 07:34 AM
  3. Sum values based on multiple criteria
    By Jorrg1 in forum Excel Help
    Last Post: 01-07-2013, 03:04 PM
  4. SUM Value With Multiple Criteria In Same Column
    By MarkJohn in forum Excel Help
    Last Post: 05-18-2012, 07:52 AM
  5. Sum values based on multiple criteria
    By vmath in forum Excel Help
    Last Post: 05-07-2012, 08:53 AM
