Thread: Splitting and merging files with VBA
    May 2013
    Hello,
    I have a folder with multiple files. in txt format. I have a code (below) that converts all to xls format. However, the tricky thing is that I want to split and combine the rows in the files based on criteria. For example I want the files divided by phases which each have starting and ending conditions (value in one of the columns). But sometimes the phases span over two files. So I want the code to be able to do somehting like "if the phase has reached end condition at the end of the file then go to next file until reaches end. etc.
    Does this make sense? Can anyone help by adding to my current code or making a separate one? tips/hints?
    Sub ConvertFiles()
    Dim strFile As String
    Dim strPath As String
        With Application
            .EnableEvents = False
            .DisplayAlerts = False
            .ScreenUpdating = False
    'Turn off events, alerts & screen updating
            strPath = "C:\Users\kdunnigan\Documents\Lyo\Freeze Dryer log by day\"
            strFile = Dir(strPath & "*.txt")
    'Change the path as required
        Do While strFile <> ""
            Workbooks.Open Filename:=strPath & strFile, Format:=2
            strFile = Mid(strFile, 1, Len(strFile) - 4) & ".xlsx"
            ActiveWorkbook.SaveAs Filename:=strPath & strFile, FileFormat:=xlOpenXMLWorkbook
            ActiveWorkbook.Close True
            strFile = Dir
        Loop
    'Opens the Workbook, set the file name, save in new format and close workbook
        With Application
            .EnableEvents = True
            .DisplayAlerts = True
            .ScreenUpdating = True
    'Turn on events, alerts & screen updating
    Suggest you attach a couple of those sample text files, and mention what exactly you expect the macro to do.
  1. Search Directories to List Files VBA
    Last Post: 04-15-2014, 08:22 PM
  2. Running a VBA in all excel files
    By msiyab in forum Excel Help
    Last Post: 12-26-2012, 01:35 PM
  3. Date References to save files using VBA Code
    Last Post: 11-28-2012, 05:48 PM
  4. Merging Data from many workbooks in to one workbook
    Last Post: 10-10-2011, 11:26 AM
  5. Count Files In A Folder VBA
    Last Post: 05-07-2011, 10:57 PM
