Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 10$ For VBA Code Split Data To Multiple Workbook Based On Unique Values In A Column
  1. #11
    Dec 2012
    i found the problem. it is becuase the source workbook file format is .xlsb and once i changed it to .xls then it worked.
    all of my source workbooks are originally xlsb is there anyway that the code will work in xlsb source workbook?
  2. #12
    Dec 2012
    i also checked with other file formats it does not work in xlsm as well. it only works in .xls seems like the code only functions in old version of excel only.
  3. #13
    IT's working fine for me in the binary format (xlsb).
    I've made a small modification. try this
    Sub SplitWorkbook()
        Dim colLetter As String, SavePath As String
        Dim lastValue As String
        Dim wb As Workbook
        Dim lng As Long
        Dim currentRow As Long
        colLetter = "P"
        SavePath = "" 'Indicate the path to save
        If SavePath = "" Then SavePath = ThisWorkbook.Path
        'Sort the workbook.
        With ThisWorkbook.Worksheets(1)
            .Sort.SortFields.Add Key:=.Range(colLetter & ":" & colLetter), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
            With .Sort
                .SetRange .Parent.UsedRange.Cells
                .Header = xlYes
                .MatchCase = False
                .Orientation = xlTopToBottom
                .SortMethod = xlPinYin
                .Apply
            For lng = 2 To .Range(colLetter & .Rows.Count).End(xlUp).Row
                If .Cells(lng, colLetter).Value = "" Then Exit For
                lastValue = .Cells(lng, colLetter).Value
                .Cells.AutoFilter field:=.Cells(lng, colLetter).Column, Criteria1:=lastValue
                lng = .Cells(.Rows.Count, colLetter).End(xlUp).Row
                Set wb = Application.Workbooks.Add(xlWorksheet)
                .Rows(1 & ":" & lng).Copy wb.Sheets(1).Cells(Rows.Count, 1).End(xlUp)
                wb.SaveAs SavePath & "\" & lastValue, 50
                wb.Close
            .AutoFilterMode = False
  4. #14
  5. #15
    It's more to do with your available system resources, than anything else I think. Can you try the same macro on a more powerful computer?
  6. #16
    Dec 2012
    the modified code you provided, worked perfectly.
    now only one issue that all the generated workbooks have the default worksheet name as "sheet1" i want the worksheet name to be the same as the source worksheet which is "GL_Details" for all those generated workbooks the worksheet name should be "GL_Details"
    can you please help on this part of the code?
  7. #17
    The reason why the modified code worked is because I reduced the range of cells to just the used range of the sheet. So it's your available resources that's cause the trouble. Having said that, I should have only used the used range instead of the entire cells.
    To add a name to the sheet, just add the below line, right after the workbook is added
    wb.Sheets(1).Name = "NameOfSheetHere"
  8. #18
    Dec 2012
    thank you very much. i do not even know your name. but i i guess that our messages have crossed before in mrexcel forums.
    so, please give pm me your paypal ID so that i send you 10 bucks.
    also looking forward for solution to my outlook project in the other thread.
  1. Replies: 10
  2. Replies: 4
    Last Post: 05-01-2013, 09:49 PM
  3. Replies: 2
    Last Post: 04-14-2013, 09:15 PM
  4. Replies: 2
    Last Post: 03-05-2013, 07:34 AM
  5. Group Pivot Data Based On Row Values In One Column
    Last Post: 10-09-2012, 11:46 PM
