IT's working fine for me in the binary format (xlsb).
I've made a small modification. try this
Code:Sub SplitWorkbook() Dim colLetter As String, SavePath As String Dim lastValue As String Dim wb As Workbook Dim lng As Long Dim currentRow As Long colLetter = "P" SavePath = "" 'Indicate the path to save If SavePath = "" Then SavePath = ThisWorkbook.Path 'Sort the workbook. With ThisWorkbook.Worksheets(1) .Sort.SortFields.Add Key:=.Range(colLetter & ":" & colLetter), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal With .Sort .SetRange .Parent.UsedRange.Cells .Header = xlYes .MatchCase = False .Orientation = xlTopToBottom .SortMethod = xlPinYin .Apply End With For lng = 2 To .Range(colLetter & .Rows.Count).End(xlUp).Row If .Cells(lng, colLetter).Value = "" Then Exit For lastValue = .Cells(lng, colLetter).Value .Cells.AutoFilter field:=.Cells(lng, colLetter).Column, Criteria1:=lastValue lng = .Cells(.Rows.Count, colLetter).End(xlUp).Row Set wb = Application.Workbooks.Add(xlWorksheet) .Rows(1 & ":" & lng).Copy wb.Sheets(1).Cells(Rows.Count, 1).End(xlUp) wb.SaveAs SavePath & "\" & lastValue, 50 wb.Close Next .AutoFilterMode = False End With End Sub
