i restarted and tried again. still get the same error. also the runtime error
do i need to add any reference from the object library?
Sub SplitWorkbook()
Dim colLetter As String, SavePath As String
Dim lastValue As String
Dim wb As Workbook
Dim lng As Long
Dim currentRow As Long
colLetter = "P"
SavePath = "" 'Indicate the path to save
If SavePath = "" Then SavePath = ThisWorkbook.Path
'Sort the workbook.
With ThisWorkbook.Worksheets(1)
.Sort.SortFields.Add Key:=.Range(colLetter & ":" & colLetter), _
SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With .Sort
.SetRange Cells
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
For lng = 2 To .Range(colLetter & .Rows.Count).End(xlUp).Row
If .Cells(lng, colLetter).Value = "" Then Exit For
lastValue = .Cells(lng, colLetter).Value
.Cells.AutoFilter field:=.Cells(lng, colLetter).Column, Criteria1:=lastValue
lng = .Cells(.Rows.Count, colLetter).End(xlUp).Row
Set wb = Application.Workbooks.Add(xlWorksheet)
.Rows(1 & ":" & lng).Copy wb.Sheets(1).Cells(Rows.Count, 1).End(xlUp)
wb.SaveAs SavePath & "\" & lastValue, 50
wb.Close
.AutoFilterMode = False
Originally Posted by
Excel Fox
I get 43 xlsb files as output
