[CODE]file is uploaded here https://skydrive.live.com/redir?resid=D7C00A2BF29043E0!257
for the spliting part code. i have found the following code from search and it somehow does not work. perhaps needs some
Code:Sub SplitWorkbook(Optional colLetter As String, Optional SavePath As String) If colLetter = "" Then colLetter = "P" Dim lastValue As String Dim hasHeader As Boolean Dim wb As Workbook Dim c As Range Dim currentRow As Long hasHeader = True 'Indicate true or false depending on if sheet has header row. If SavePath = "" Then SavePath = ThisWorkbook.Path 'Sort the workbook. ThisWorkbook.Worksheets(1).Sort.SortFields.Add Key:=Range(colLetter & ":" & colLetter), _ SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal With ThisWorkbook.Worksheets(1).Sort .SetRange Cells If hasHeader Then ' Was a header indicated? .Header = xlYes Else .Header = xlNo End If .MatchCase = False .Orientation = xlTopToBottom .SortMethod = xlPinYin .Apply End With For Each c In ThisWorkbook.Sheets(1).Range("P:P") If c.Value = "" Then Exit For If c.Row = 1 And hasHeader Then Else If lastValue <> c.Value Then If Not (wb Is Nothing) Then wb.SaveAs SavePath & "\" & lastValue & ".xlsb" wb.Close End If lastValue = c.Value currentRow = 1 Set wb = Application.Workbooks.Add End If ThisWorkbook.Sheets(1).Rows(c.Row & ":" & c.Row).Copy wb.Sheets(1).Cells(Rows.Count, 1).End(xlUp).Select wb.Sheets(1).Paste End If Next If Not (wb Is Nothing) Then wb.SaveAs SavePath & "\" & lastValue & ".xlsb" wb.Close End If End Sub
https://eileenslounge.com/viewtopic.php?p=326972#p326972
https://eileenslounge.com/viewtopic.php?p=326853#p326853
https://eileenslounge.com/viewtopic.php?p=326446#p326446
https://eileenslounge.com/viewtopic.php?f=27&t=41986
https://eileenslounge.com/viewtopic.php?p=325605#p325605
https://eileenslounge.com/viewtopic.php?p=325548#p325548
https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGADdPM65i9PG
https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGADdPQHFk_zm
