I think we may almost know what is to be done !
These are the some of the criteria my next code will work on: ( These are those criteria which were unclear until now ! )
Holidays are shown in yellow background color
Normal working days have no background color
The data rows to be considered are those filled with dates in column E
“TOTAL NO. OF DAYS” ( to be placed by the code in cell C34 )
For all Months, the “TOTAL NO. OF DAYS” ( to be placed in cell C34 ) is not necessarily the number of days worked.
The formula for calculating this is:
_Assuming the employee is not Absent for any day, then the “TOTAL NO. OF DAYS” is always taken as 30
_ If the employee has one or more normal days of absence, ( normal days with no total working hours ), then the formula for calculating “TOTAL NO. OF DAYS” is as follows:
TOTAL NO. OF DAYS = 30 – ( Count of “ABSENT” )
“ABSENT” ( to be written in some rows in Column K by the program )
Count of “ABSENT” is the number of occurrences of ABSENT in column K in the final ( After ) Worksheet “ABSENT” is to be written in some rows of column K by the code under certain criteria.
( “ABSENT” is not necessarily the normal working days in which an employee is absent and / or has no total working hours. )
“ABSENT” is to be written in column K by the code under the following criteria:
_ For the rows of all normal days when the employee has no working hours, ( days when the employee is absent ), “ABSENT” is to be written in column K.
_ In addition , should it occur that an employee is absent for both the days before and after a holiday, then for the ( Holiday ) row in between those two days, “ABSENT” is to be written in column K.
( No consideration of this ““ABSENT” criteria thereof” is made for the case of a Holiday at the first or last “Entries” )
( The number of “Entries” is taken as the filled dates in column E )
Column L ( help column )
Nelson has chosen the second code. It puts formulas in cells C34, G34, and J34.
This requires “H” or “N” to indicate Holiday or Normal working day. This will be written by the code in column L
_......................
Nelson:
Please examine the above criteria , and tell me if this is correct ?
